Help with adjusting window... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2007, 07:38 PM   #1 (permalink)
View 02Camry_TX's Photo Gallery
There are 4 bolts for the eletric motor for the power windows....well...looks like 2 of mine worked themselves loose over the years. The end result...the window would not roll all the way up/down and the pieces of the scissor assembly that rolled the window up and down were scraping against the tint of the window...well...the bolts had fallen into the bottom of the door and I actually found both (shocker) and got them back in...but now when I roll up the window it is slightly ****-eyed. (Very easy to see because of the tinted windows). Basically...the top left corner (or top back depending on how you are looking at it) needs to go further back towards the back of the car. Anybody know of anyway to adjust any part of the window assembly? So I guess what needs to happen is that the right side of the window needs to move up a little bit or the left side down. This should allow the window to roll up "square". Anybody have any ideas?
This is an 02 Camry by the way.
Jim
02Camry_TX is offline   Reply With Quote
Old 04-29-2007, 09:15 PM   #2 (permalink)
Well....after taking another look at the door mechanism...I'm quite certain the problem is that part of the scissor assembly is bent. I believe that is the "play" in it....think I am going to see if I can find one off a Camry in a junk yard.
Need help with 99 Camry window repair! aznarkitekt 3rd & 4th Generation (1992–1996 & 1997–2001) 4 06-13-2011 03:35 AM
Window Fix - Door Panel Removal Zerzil Archived Corolla threads 6 04-16-2007 11:21 PM
Window Tint Noise tjg184 2nd Generation (2005+) 8 09-06-2006 12:36 PM
Replacement Rear Window (with topper) peers 2nd Generation (2005+) 2 08-26-2005 11:45 PM
Camry RH Window regulator & motor needed total1 Camry & Solara Lounge 9 05-24-2005 06:04 PM
