Passenger seat noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2007, 10:26 AM   #1 (permalink)
View mtnet2000's Photo Gallery
Gen6 Passenger seat noise
My 07 Camry's passenger seat make a rattling sound when I go over bumps and the seat is not occupied. Any one else experience this problem? I thought it was a loose strut on the passenger side, but it's the seat!
2007 Barcelona Red LE I4
mtnet2000 is offline   Reply With Quote
Old 05-01-2007, 10:37 PM   #2 (permalink)
View moodyblue_02's Photo Gallery
could be the seatbelt hitting the door. try to buckle it in and see if you still hear the rattle.
moodyblue_02 is offline   Reply With Quote
Old 05-02-2007, 02:07 AM   #3 (permalink)
View 07Camry22s's Photo Gallery
Gen6 Passenger seat /tranny problems
My 07 camry has the same issue with the passenger seat , seat will make a rattling noise when driving , also noise can be dupilcated when taping on back of the chair... I took it in for service to my local jack safro toyota dealer and they removed the seat and broke it down and determined that there is no serviceable parts, only option is to replace the seat which is $7000.00 they say .. Iam waiting on toyota to have a field engineer come out and check out the problem and to ok replacement seat ... And to top it off, The tech who took the seat out for inspection damaged the door sill, rubbering molding and plastic pillar behind seat belt and put a gouge in door panel and small scuffs by the side off the glove box just by removing and reinstalling seat... so now i play the waiting game to get my car fixed .
So far toyota has let me down.. Camry only has 15,000 miles and already needs
replacement transmisson due to 3rd and 4 gear flares
replacement seat due to noises
Already has had passenger visor mirror replaced due to faulty switch .
07Camry22s is offline   Reply With Quote
Old 05-02-2007, 10:49 AM   #4 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $172825
View JSM1284's Photo Gallery
My pass seat back rattles too. Do what I havent tried, if no one is sitting in it, put it in the all the way up-right position and see if it still does it.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 05-02-2007, 12:03 PM   #5 (permalink)
I keep my laptops case on it and it kind of dampers it, but your right, I can replicate it by hitting the seat, going to take it back to toyota for service, $7000!!!! The pulling your leg
Old 05-02-2007, 03:36 PM   #6 (permalink)
2008 SE V6
thoots's Avatar
View thoots's Photo Gallery
....Just another reason why I aways recommend AGAINST having a dealer do any "rattle fixes" or similar work.
The "tech?"
I'd call it this way:
The service monkeys will have to tear your interior apart. Oh, call it "dis-assemble" if you'd like, but they will tear your interior apart. Actually, use any term you'd like for the "quality" of their work: Slipshod, sloppy, careless, incompetent, lousy, stinking -- whatever. But, just expect that you will wind up with a horrifying mess beyond anything you could possibly imagine. And, of course, they won't fix any rattles.
So, that's the story -- your dealer is far more likely to DAMAGE YOUR CAR than it is to actually fix anything. Read around the board for other horror stories like this -- for every "success" story, you'll find ten or more "no fix" or "worse" stories -- where they actually damaged the car. And, it's oh, so very likely that you'll wind up with far more rattles than you ever had before they touched your car.
I still maintain that we have to figure out exactly what is rattling or making any noise that we don't think we should be hearing, and then come on back here and we'll talk about how to go about fixing it. Your dealer just won't take care of your interior -- and it most certainly won't put things back together nearly as well as they were in the first place -- so you need to take care of your own car, with the patience and the care it deserves!
At any rate, "sorry to hear your story of woe." Everyone else -- LEARN from this example!
thoots
thoots is offline   Reply With Quote
Old 05-02-2007, 04:31 PM   #7 (permalink)
When I had the noise reduction kit installed, they did something to the AC controls where it now has friction to it when I turn the knobs? I was so nervous knowing that they where going to be ripping my dash apart! So when I bring it in for the seat noise, I'm going to have them check it!
Old 05-02-2007, 05:43 PM   #8 (permalink)
JSM1284's Avatar
There is actually a TSB about seat squeeking.....
2005 Lexus ES330
Old 05-03-2007, 02:26 AM   #9 (permalink)
View netman's Photo Gallery
When is the production date for your vehicles??
Mines is a 01/07 LE I4 and it's fine
Knock on wood.
netman is offline   Reply With Quote
Old 05-03-2007, 09:04 AM   #10 (permalink)
my MPG>yours
View kriskraut's Photo Gallery
The JBL amp is under the seat too, so make sure the plastic casing around it isn't making a tapping sound. Mine was when I was going over uneven pavement, so I applied some foam and haven't had noice since.
07 TCH
kriskraut is offline   Reply With Quote
Old 04-08-2008, 11:13 PM   #11 (permalink)
View Fudge's Photo Gallery
I purchased a new 2008 SE 5 speed 4 weeks ago and I am noticing the rattle in the passenger seat when it is not occupied and I go over bumps. I also thought it was the seatbelt but it's not. I am able to make it go away if I hold the plastic trim on the side of the seat. That's the piece with the seat back handle sticking out of it. I thought it might be the handle but it's not. I think it's something under the seat resting against the trim. Has anyone found a solution to this seat rattle? I haven't gone to my dealer yet, I figured I would check with you guys. I love my new car but this is going to drive me nuts.
Fudge is offline   Reply With Quote
Old 04-09-2008, 12:59 AM   #12 (permalink)
phuangk's Avatar
View phuangk's Photo Gallery
Gen6
The TSB about seat squeeking is for the driver side seat, right? correct me if I am wrong...
http://www.djmase.com/tsb/Camry2007/nv002t07.pdf
2008 Camry SE 4cyl
phuangk is offline   Reply With Quote
Old 04-09-2008, 02:14 AM   #13 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
Gen6
$7,000 for a seat??!!
If you have an LE, it is only $2,563.50. Even the XLE only goes up to 4k.
I hope your seats are made of gold for them to quote you a price like that. Or at least give you a 'happy ending' while they are at it...
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 04-09-2008, 09:26 AM   #14 (permalink)
Hey phuangk,
That TSB covers the drivers seat. This noise is in the passenger seat. It only happens when the seat is empty and I go over a bump. It's probably loose trim because I can make it stop if I put my hand on the plastic on the side of the seat bottom. I guess I need my dealer to look at it. Thanks the link though, I have saved a copy of the drivers seat TSB just in case.........
Old 04-09-2008, 09:56 AM   #15 (permalink)
phuangk's Avatar
Gen6
Originally Posted by Fudge View Post
Hey phuangk,
I have the exactly the same issue as yours on my passenger seat... but I still cannot reproduce the problem... It happened sometimes especially when i go over some bumps or drove on a bumpy road... It happened more when weather is cold. I am not sure if the noise came out from seat or it's one of the TSB regarding the Instrument Panel Rattle Noise (T-NV008-07-Instrument Panel Rattle Noise)
2008 Camry SE 4cyl
04 Tundra ratttling noise in passenger side front end BIGRAZ 1st Generation (2000–2006) 11 04-12-2007 08:09 PM
Begone, damn seam, BEGONE!! thoots 5th & 6th Generation (2002-2006 & 2007-2011) 20 03-06-2007 07:01 AM
scraping noise (passenger side) while turning left AyzhenInvasion Camry & Solara Lounge 1 11-27-2005 04:15 PM
'05 Passenger Seat Belt Warning Buzzer goaway113 5th & 6th Generation (2002-2006 & 2007-2011) 12 03-29-2005 12:12 PM
