I have a Gen 5.5 Camry V6 and wasted a friday trying to install some new rotors on the car. I got the brakes and bolts off and the only thing left was to remove the old rotor and put in the new one. That thing is HARD to get off, I don;t know whether i am doing it wrong or it is too rusted to get off. I tried banging it with a rubber mallet w/ WD40, but it ate away at the mallet. Soo.........what do I do now?
the service manual just said remove caliper bracket bolts, and the rotor should be free from hub, sometime rotor is rusted on the hub as it ages, i've learn two way to remove stuck rotor:
way one, there should be two small hole, i don't recall exact size, but i found two right size bolts and turn both bolts evenly on the rotor to push the rotor away from hub.
way two is use force, use a two by four wood stud, place on rotor, and use a big hammer on rotor and hit wood stud hard until rotor comes off.
You can try this, reinstall all the parts and put the wheels back on the car. Run car, put in drive and drive forward a little and apply brakes, go in reverse and go backward, apply brakes, go back and forth several times, apply rust penetrant to stud area but dont get it on pads of course. The idea is to rock the rotors a little to loosen them some.
If the rotor is bad and getting tossed anyway, then as a last resort, a large three-jawed puller can be used to help remove it. (I wouldn't try this on a rotor to be used again because there's a good chance the puller might ruin it.) These pullers are about $22 a set at www.harborfreight. com - But go slowly and bang on the rotor as you tighten the long nut on the puller, and this ought to take the rotors off.
I finally got that rusted old rotor off with a 7mm threading screw. That made me so happy... Now that i think about it, the reason that it was such a pain to take off was that my car always been hit with water sprinkers and it rusted my rotors extra fast. But thanks for the tips guys.
"Now that i think about it, the reason that it was such a pain to take off was that my car always been hit with water sprinkers and it rusted my rotors extra fast. But thanks for the tips guys."
If you think the sprinklers are a problem, try moving to the snow belt area where they use road salt in the Winter. Then you will know what rusted on really is.
The 2 screws were the right way to go. Glad it's finally off.
actually i will be moving out to downers grove near chicago this fall for pharmacy school. I guess i will be enjoying my shiny new rotors for only about half a yr before winter comes.
Next time, try using some high-temp anti sieze paste where the rotor touches the hub and stud threads. Dont put anti sieze on the studs threads, just at the bottom part the rotor goes over. And you want to keep the anti sieze away from the rotor part of course.
Mike
I hear ya man. In my neck of the woods(Northwest Pennsylvania) the weather sucks in the winter. Had to go buy a new snowblower!
