CHANGING THE MODE
The mode toggles through from mode
1 to mode 4. To change the mode, do
the following:
1. Shift the shift lever into the “P” position
and close all doors.
2. Push the power door lock switch on
the rear side to unlock the doors.
3. Turn the ignition switch to the “ON”
position.
4. Within 5 seconds after the ignition
switch is turned to the “ON” position,
push and hold the power door lock
switch on the front side for about 5
seconds.
5. Open door warning light will flash to
indicate that the mode has been
changed.
The flashing of the open door warning
light indicates the mode which has been
selected.
Flashing once, the function has
changed to mode 1.
Flashing twice, the function has
changed to mode 2.
Flashing three times, the function has
changed to mode 3.
Flashing four times,
Ok, i just tried it, but it doesn't work. I looked up my "real" version of the owner's manual, it wasn't listed. Maybe it only applies to US-camrys ...
I really think its not wired up for that function..
