wheel width? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2007, 04:31 PM   #1 (permalink)
View dunphy021's Photo Gallery
Gen5 wheel width?
i have a gen 5.5. keep in mind this is for performance application, i want my car to handle as good as possible.
im getting 18" rims, what width should i be looking at? i was thinking 8" but i was also looking into wider, such as 8.5" and 9"
would it be stupid to get narrower rims in the back (ex:8.5 front 8 rear), and use spacers to even it out?
if i were to get 8.5" or 9", should i look into getting fender flares?
thanks for any help.
dunphy021 is offline   Reply With Quote
Old 05-05-2007, 07:46 PM   #2 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
I would say go with 235 or 245.
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 05-05-2007, 11:23 PM   #3 (permalink)
BANNED
View w203's Photo Gallery
18" wheels aren't really performance oriented unless you get the expensive lightweight which I don't think you'll get. Since you want a staggered setup (on a FWD) then I am guessing you are going for straightline performance. And if that is the case, choose your tires and work from there.
w203 is offline   Reply With Quote
Old 05-06-2007, 09:33 AM   #4 (permalink)
View Aceventura9586's Photo Gallery
i've got the nice lightweight 18" bbs wheels wrapped in aggressive yokohama's. the tires are 235. and i've experimented. turns i used to have to slow down for, i can take like a rally car now. i'm happy with my setup. 18's all around for me, just got them a couple weeks ago too. VERY NICE(borat accent)
Aceventura9586 is offline   Reply With Quote
Old 05-06-2007, 02:05 PM   #5 (permalink)
Webb26's Avatar
View Webb26's Photo Gallery
I agree..but even then, 18's as a performance wheel is not really the best choice here...but just my opinion
Webb26 is offline   Reply With Quote
Old 05-06-2007, 11:36 PM   #6 (permalink)
it's a mix of show and performance that i am looking for. i'm going to get the lightest 18s i can afford. i will probably drop like 1100 or 1200 on the set. also going to get a nice set of 14"s or 15"s for the track, mated up with a set of slics. so can we get back onto the real question, which is width, and not wether it is 17" or 18"? thanks.
Old 05-07-2007, 06:25 PM   #7 (permalink)
scamry's Avatar
Gameroom cash: $193325
View scamry's Photo Gallery
8.5 is pretty much the limit. i had 19 x 8.5 with a 225/35 tire, and i was hella flush with the fender, so with a drop it would probably take some work(just fender roll/pull)
why would you want narrower wheels on the rear?
I miss the old days of TN.
scamry is offline   Reply With Quote
Old 05-07-2007, 07:50 PM   #8 (permalink)
Webb26's Avatar
Well depends what offset you wanna run, and how low you wanna drop. You gotta help us understand your situation before we can help you out with your problem. thanks
Steering Wheel Noise Trd_Thunder 2nd Generation (2005+) 9 02-21-2007 12:05 PM
Dealer told me my steering wheel is supposed to be crooked! da5176 1st Generation (2001–2007) 8 06-13-2006 09:38 PM
repair steering wheel - wear on spokes celicaGTswan85 General Discussion 4 04-07-2006 04:45 PM
Front Wheel Drive To Rear Wheel Drive theman33b Camry & Solara Lounge 15 12-15-2005 03:03 AM
Stock wheel width??? nomad 2nd Generation (2005+) 2 11-16-2005 11:23 PM
