Changing Oil with 2GR-FE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2007, 10:09 PM   #1 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Gen6 Changing Oil with 2GR-FE
I've read this: http://toyotanation.com/forum/t186039.html
So the 07 Camry V6 uses a different type of oil filter? Do I have to get that from the dealership directly? Or is there a way for me to order in bulk online for a better price but same Toyota quality.
Anything special related to changing the oil on the 07 Camry V6s? I haven't looked under it yet, but it seems that the oil filter is just a bit bigger and more complicated, but still a screw off and screw on thing?
Also, the manual recommended 5W-30, but I've heard of TSBs that allows 5W-20 for the 2GR-FE engine as well. Would it be better to buy 5W-20? Do they have Mobil1 5W-20 Synthetic?
Thanks a lot.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 05-06-2007, 10:50 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The filter is a cartridge so you do not replace the entire canister like what you may have done in the past. You replace the filter element and a couple O-rings.
Thanks a lot.
Easiest way to find out whether or not Mobil makes Mobil 1 in 5W-20 would probably be to check their website. But that doesn't mean that you'll be able to find it in stores near you.
2007 Camry 2.4L 5M
Old 05-07-2007, 10:28 PM   #3 (permalink)
View mannypeligroso's Photo Gallery
Well as far as I know theres nothing special about changing the oil filter on the camry v6,except that its the cannister type.Alot of people recommend using aftermarket oil filters like fram because they're alot better than the original toyota oil filter.You could go to walmart and find it.If you're really picky about choosing then you could try the trd oil filter specially designed for the 07'camry v6.Here's the link.Hope it helps.
http://www.trdsparks.com/displaypart...1&parts_id=316
mannypeligroso is offline   Reply With Quote
Old 05-08-2007, 06:40 AM   #4 (permalink)
07 Camry SE V6
wilfredcruz's Avatar
View wilfredcruz's Photo Gallery
even that many places it says this filter is for the V6. It is not. I had it and returned it.
It is for the 2006 engine
2007 Camry SE V6 /Leather/sunroof/JBL
Added: XM Sat Radio (Toyota), 18in Wheels (Rial), 3M Tints (35%), LED Interior lights. TRD Lowering Springs
Removed: Camry Se Badges
wilfredcruz is offline   Reply With Quote
Old 05-08-2007, 10:15 PM   #5 (permalink)
are you sure its for the 2006 v6? I mean it says for 2007 camry v6.Did the one you return look like the same white color cannister or was it red? I know preiviously on the 06' and older camry's trd had one that looked identical,but it was red.
If the oil filter is for the 06 v6 camry then someone should call those guys and complian about false advertising.They's shouldn't say its specifically designed for the 07' v6 camry when its not.
Old 05-09-2007, 06:49 AM   #6 (permalink)
07 Camry SE V6
it isdefintly not for the 07 V6.
I hadone hat home it was white.
also same part number but ending at -06 instead of -04 is the one for the 2AZ engine
maybe f0r 06 Solara V6.
Old 04-25-2008, 04:36 PM   #7 (permalink)
View ChiTDI's Photo Gallery
Cartridge oil filters
"So the 07 Camry V6 uses a different type of oil filter? Do I have to get that from the dealership directly? Or is there a way for me to order in bulk online for a better price but same Toyota quality."
fleetfilters.com
Napa name, manufactured by Wix, but not necessarily in NC.
Haven't got the "special tools" question resolved yet.
Canister filters are really good and once you're accustomed to them, very easy to change.
ChiTDI is offline   Reply With Quote
Old 04-25-2008, 04:52 PM   #8 (permalink)
BlewCam
View jamesxsemaj's Photo Gallery
funny how this subject came up, i was browsing youtube for some gen6 cam vids and came across the DIY oil&filter change.
http://youtube.com/watch?v=LXLnyzA-6tM
zero eight' (blue mag) XLE I:four stox =/
.so jealous of everyones mods.
jamesxsemaj is offline   Reply With Quote
Old 04-25-2008, 05:31 PM   #9 (permalink)
View Mike Murrell's Photo Gallery
NAPA now makes a quality oil filter for the 2GR-FE motor.
Part number 7047
This URL has photos/instructions for an Avalon 2GR-FE oil/filter change. Same 2GR-FE that goes in the Camry.
http://members.cox.net/n0v8or/avalon_oil_change.pdf
Mike Murrell is offline   Reply With Quote
Old 04-25-2008, 09:45 PM   #10 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
View fdexclpl's Photo Gallery
This tool will make it much easier to remove the filter housing:
http://www.asttool.com/detail_page.php?from_search=y&tool_number=TOY%2064 0&total=11&offset=0&stype=bynat&nationality=asian& category=Oil%20Change%20Products
And you can buy it here:
http://www.toolsource.com/toyota-fil...-p-100298.html
Trust me, it makes things much easier.
'07 Camry LE V6 - Blue Ribbon Metallic - 6-disc JBL - Moonroof
Someday I will list my mods here
Originally Posted by TRD VVTi View Post
I am a hater in one regard, I hate stupid.
fdexclpl is offline   Reply With Quote
Old 04-26-2008, 01:21 AM   #11 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
Thanks a lot.
If 5W-30 is recommended, why would you want to use 5W-20? If you want, they are all available as full synthetic..but, again, why?
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 04-26-2008, 02:11 AM   #12 (permalink)
View MAP1234's Photo Gallery
Cool! But damn, that was a LONG filter change...
MAP1234 is offline   Reply With Quote
Old 04-28-2008, 04:26 PM   #13 (permalink)
Those V6s use six and a half quarts of oil, that filter better be a good one.
Old 04-28-2008, 05:31 PM   #14 (permalink)
2GR FTW
darksparkz's Avatar
6.5 quarts? Really? I always thought it was 6 quarts.
I've got it all down, but the only thing that I can't remove is the small cap for the smaller o-ring itself, when I try to remove it, it turns the whole filter canister.
Old 04-28-2008, 05:33 PM   #15 (permalink)
NO SPAM!
Black08SEV6's Avatar
View Black08SEV6's Photo Gallery
6.5 is the dry number (including filter). Correct me if I'm wrong, but I think you'd use 6 quarts at the oil change. Also, if you use bottled oil you *might* not get exactly 6 qts. as you can't truely drain the bottle 100%.
Black 08 Camry SE V6
Black08SEV6 is offline   Reply With Quote
7AFE oil-burning knowledge pool Piloter 7th Generation (1993-1997) 13 02-29-2012 08:35 PM
oil change interval question nomad 2nd Generation (2005+) 15 06-29-2010 09:01 PM
2002 Sienna Sludge despite changing oil every 3k? wjchun 1st Generation (1998-2003) 16 05-12-2007 12:31 AM
Observations from changing Oil, Tranny, Transfer case, F&R Diffs demoncleaner 2nd Generation (2005+) 10 09-14-2006 06:35 PM
Changing engine oil question... speedemn General Discussion 7 10-26-2001 05:13 PM
