Disabling the TPMS? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2007, 07:18 PM   #1 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Disabling the TPMS?
I was reading through the manual, and I stumbled upon the TPMS section. It said that when you install new tires and the light comes on, to reset the system by pressing the "SET" button near the glove box. From my understanding, it was basically saying that because there might be a difference in pressure, that you should set it so it knows what the normal pressure is.
Now say you remove the wheels and sensors, would it be possible to "set" it so it thinks that 0 PSI is the normal pressure? That way you can have the sensors in the trunk or something and not worry about swapping over the sensors or covering up the light with tape?
geoff5093 is offline   Reply With Quote
Old 05-08-2007, 06:31 AM   #2 (permalink)
07 Camry SE V6
wilfredcruz's Avatar
View wilfredcruz's Photo Gallery
No you can't set it to 0. The computer will tyrn light on since it will finf no communication with the sensors. I have mine off with my aftermarket wheels. Light is only on half of the time. Goes off once i out the stock wheels for the winter.
2007 Camry SE V6 /Leather/sunroof/JBL
Added: XM Sat Radio (Toyota), 18in Wheels (Rial), 3M Tints (35%), LED Interior lights. TRD Lowering Springs
Removed: Camry Se Badges
wilfredcruz is offline   Reply With Quote
Old 09-27-2008, 10:43 PM   #3 (permalink)
2009 Corolla LE
redmgb's Avatar
View redmgb's Photo Gallery
Japan turning off TMPS.....
how you turn it off ?
with that reset button ?
any procedures for how to reset ?
redmgb is offline   Reply With Quote
Old 09-29-2008, 09:26 PM   #4 (permalink)
geoff5093's Avatar
Nice bump...
You can't turn it off via the reset button, or turn it off period.
Old 09-29-2008, 10:25 PM   #5 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Originally Posted by geoff5093 View Post
Nice bump...
How's life with your new Tacoma? Hope all is well.
Old 09-29-2008, 10:31 PM   #6 (permalink)
i love emmanuelle chriqui
LXS-mode's Avatar
View LXS-mode's Photo Gallery
hey i remember geoff. the guy with the red LE/XLE with grey rims and chrome overlayed grill.. nice choice on the tacoma. your seafoam guy too right?
What is it about...Stance? Flushness? Stretch? or Pokin Out?
Clean...Elegant...Simple...yet so GANGSTA!!!
LXS-mode is offline   Reply With Quote
Old 09-29-2008, 10:33 PM   #7 (permalink)
Here and there...
You got it. He was a very active member on this Gen5&6 forum.
Old 09-30-2008, 06:26 PM   #8 (permalink)
geoff5093's Avatar
hehe, I still pop in from time to time
The new Tacoma is great, I love not having to slow down to 2MPH to go over a speedbump or hole, lol.
BTW, I had an LE:
You can but it from the dealer if you want, haha!!
http://toyota.grappone.com/used-inve...seHistory=true
Old 10-01-2008, 09:44 AM   #9 (permalink)
Joined the dark side. :D
Gameroom cash: $654691
View workerant's Photo Gallery
Nice bump...
Can't turn it off? Than shut it off...by to put a sticker there to block the light.. or open the instrument panel and remove that light bulb.
Of cause the correct way is to correctly set the TPMS or if it's stolen than buy a new TPMS.
I don't think anyone regular driver should touch this reset button. It is set to a standard 32psi for best performance and durability. Once your tires are within this 32psi range the light will turn off almost right away.
I can go 25 or 35mph over speed bump just fine in my Camry SE with OEM height. Is this what you love most in your Tacoma?
workerant is offline   Reply With Quote
Old 10-01-2008, 03:37 PM   #10 (permalink)
geoff5093's Avatar
My car was lowered on TRD springs, I had to enter some driveways at angles also because otherwise my bumper would scrape, lol. What I love most about my Tacoma will be coming this winter, being able to drive in the snow and not worrying as much about getting stuck.
Old 10-01-2008, 04:01 PM   #11 (permalink)
geoff5093's Avatar
BTW, all of my stuff is for sale in the "For Sale" section, check it out!
Old 10-01-2008, 07:58 PM   #12 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $455050
View Luna2's Photo Gallery
Gen6 TPS Light Disable, Maybe....
I think that turning off the TPS light may be feasible, without any sensors.
Read the following:
The Tire Pressure Warning ECU is mounted behind the glove box, near the A/C Amplifier & Certification ECU. [Ref Page 20 of the 2007 Camry Electrical Wiring Diagram].
There is a light blue wire on pin 5 of the TPS ECU connector [reference page 270] that goes to the combination meter pin 7(A), which turns on the TPS Warning Light.
The question is…. Is the voltage applied, OR is the voltage removed, to activate the warning light? If applied, at what level?
I do not recommend unplugging the TPS ECU, the computer might set a warning light for the interruption of the CAN I/F to the TPS ECU.
The voltage needs to be monitored on pin 5 and let the air out of one tire to set the TPS light, then, proceed from there. I don’t have a sheltered area to do this here, and we needed the rain, bad…. Maybe someone has the time to do this and respond before the weekend.
Now, What do you think???
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Old 10-01-2008, 09:57 PM   #13 (permalink)
geoff5093's Avatar
From what I remember the TPMS ECU/fuse was also tied into other ECU components. As for your idea though I have no idea, lol.
Old 10-01-2008, 10:34 PM   #14 (permalink)
just a nobody
Wouldn't it be easier to just get a steel rim, put all the sensors on it, pump it up and leave it in the trunk.
N.E.O.
Old 10-02-2008, 04:17 AM   #15 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gen6
You are correct, that was one reason why I looked at disabling the TPS light "trigger". The other reason was the CAN I/F.
MFG 02/25/2010
Stock, Shucks!
TPMS bypass DIY ncpaladin 2nd Generation (2005+) 127 08-19-2011 10:06 AM
TPMS light was on this morning.... BigWillie 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-23-2007 11:32 AM
TPMS Questions Brandon402 5th & 6th Generation (2002-2006 & 2007-2011) 11 02-23-2007 12:11 PM
06 Tpms ncpaladin 2nd Generation (2005+) 3 08-11-2006 02:49 PM
Disabling TPMS in the 07 Camry Klutch 5th & 6th Generation (2002-2006 & 2007-2011) 2 06-08-2006 10:18 AM
