2007 Mud Flaps - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2007, 07:13 AM   #1 (permalink)
eflw1029's Avatar
View eflw1029's Photo Gallery
Gen6 2007 Mud Flaps
I scored a new set of 2007 Camry mud flaps on ebay to help resolve the issue of minimizing the trash tossed up via the front drive wheels on the front quarter panels and rocker panels. Installing the front mud flaps were a non event but I am hesitant about installing the rears because I have to drill two holes per side then install tinnerman nuts to accept the supplied self tapping sheet metal screws. I cannot see drilling holes in two perfectly pristine rear quarter panels as it will eventually expose the rear quarters to rust formation. Has anyone determined a good tip or trick to avoid this srilling for the rears? Right now I'm debating not installing the rear flaps for this reason.
2007 V6 Camry LE
Desert Sand Mica
16" Alloys with McGards
Vin #035xxx
Kentucky Build Date 03/07
eflw1029 is offline   Reply With Quote
Old 05-08-2007, 09:31 AM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Good God, it's plastic!!!!!!!!
Haven't you ever touched it?
Old 05-08-2007, 11:22 AM   #3 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
use double sided tape if ur too afraid
My Partial Partout!!!
Photo Album
Old 05-08-2007, 12:30 PM   #4 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
Yeah, I was a bit nervous about drilling holes into my brand $28,000 car... but eventually I just decided that it was time. It's actually quite easy... except that you have to take off the rear tires.
About rust forming.... like the guy said above, it's plastic, so no worries about rust.
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 05-08-2007, 01:02 PM   #5 (permalink)
Sap
sappy74's Avatar
View sappy74's Photo Gallery
You will be drilling 2 holes thru a thin layer of plastic, no need to worry about rust. Very quick and easy.
Hardest part is removing the heavy wheels.
Pics of my 07 Camry XLE V6
Added: SE lip spoiler, BEC105 back-up camera, mudguards, OEM moonroof wind visor, WeatherTech side window deflectors, tint 50%F/20%R, XenonDepot 6000k HID, upper/lower/fogs chrome trims.
sappy74 is offline   Reply With Quote
Old 05-08-2007, 02:36 PM   #6 (permalink)
eflw1029's Avatar
Gen6 Plastic?...duh!
I love you guys...I had no idea the rear quarter panels were made of plastic. Anyway, thanks. Found out that even with a right angle drive drill it's still way too tight making it impossible to drill unless you physically remove the rear wheels.
2007 V6 Camry LE
Desert Sand Mica
Vin #035xxx
Old 05-08-2007, 03:54 PM   #7 (permalink)
View brian01togo's Photo Gallery
i went with oem mudgaurds no drilling necessary !
brian01togo is offline   Reply With Quote
Old 05-08-2007, 05:30 PM   #8 (permalink)
yeuemhoai's Avatar
View yeuemhoai's Photo Gallery
I think oem mudguards require drilling. I always buy cars w/o them and put them on when I got cheaper on ebay :-)
'07CamryLEV6|Whyt|V4|EF|Mudguards|All-weatherMats|LipSpoiler|Tinted|3MProtector|LEDInterior|SERims|Xtreme5000K| LEDTaillights...
'01LexusRX300|PearlWhyt...
'96CamryLEV6CollectorEd.|PearlWhyt...
yeuemhoai is offline   Reply With Quote
Old 05-08-2007, 06:12 PM   #9 (permalink)
eflw1029's Avatar
yeuemhoai is correct but I waited to respond back to brian01togo's post. Obviously brian01togo did NOT purchased oem mud flaps as he would have known the genuine oem toyota rear mudflaps certainly require drilling of two holes for each of the rear flaps. BTW, I got my new sets of 4 flaps for $24 plus $6.00 shipping which was the best I could find on ebay.
2007 V6 Camry LE
Desert Sand Mica
Vin #035xxx
Old 05-08-2007, 07:31 PM   #10 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
You are not drilling iinto the rear quarter panel. You are drilling into the rear bumper cover.
$24 for a set of 4? Did you get black ones?
My painted ones were a bit more:
2007 Camry 2.4L 5M
Old 05-09-2007, 04:43 AM   #11 (permalink)
eflw1029's Avatar
Standard black genuine toyota mud flaps. I couldn't see paying $77 for the painted color matched flaps. Still getting a good education from all the posts here. I literally had no idea the rear mounting area was non-metal...all I do know is as you drive all the wheels kick up a lot of road spray, trash, and whatnot eventually making the rocker panels prone to chipping. Not much more accessories to purchase...market is very limited in what you can get. I still want to get some autopmeter gauges but autometer does not make any a-piller pods. I was thinking about both a oil pressure and coolant temp gauges but have no where to mount the gauges. I could improvise mounting where the aux jack door is but would sacrifice losing the storeage area. Decisions, decisions, decisions!!!!
2007 V6 Camry LE
Desert Sand Mica
Vin #035xxx
Old 05-09-2007, 09:25 AM   #12 (permalink)
Have you considered a Scangauge II? I think it displays all the values you listed, but only 4 at a time on LCD display.
2007 Camry 2.4L 5M
Aftermarket mud flaps? Sonny 2nd Generation (2005+) 12 04-30-2010 02:46 PM
Mud flaps, springs, floor mats, and tires from trd sport for sale TacomaFourplay 2nd Generation (2005+) 5 03-22-2010 07:50 PM
2007 Toyota Photos Help! Autoboy Off Topic 7 01-03-2007 09:55 AM
MUD FLAPS (5th generation) xav_hlub_koj Celica Forum 2 07-02-2004 11:11 AM
