2007 Camry Service Bulletins Warranteed? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2007, 11:32 AM   #1 (permalink)
View JayJ's Photo Gallery
2007 Camry Service Bulletins Warranteed? Have any of you had this done and covered by dealer? Because I definitely have sporadic problems with the tranmission getting stuck in gear and not shifting up. Like the RPM will just shoot up to 5,000+ RPM instead of shifting to next gear. Also when decelerating, the RPM will drop below 1000RPM even though im on highway going at 65mph.
1 of 5: POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Date: JAN 20073RD - 4TH GEAR SHIFT FLARE. ( NHTSA ITEM NUMBER - 10020993 )2 of 5: POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Date: DEC 2006TCM CALIBRATION UPDATE MIL ON DTC P2716. ( NHTSA ITEM NUMBER - 10020867 )3 of 5: TIRES:PRESSURE MONITORING AND REGULATING SYSTEMS
Bulletin Date: NOV 2006DIRECT-TYPE TIRE PRESSURE WARNING SYSTEM DIAGNOSTIC TIPS. ( NHTSA ITEM NUMBER - 10021180 )4 of 5: ENGINE AND ENGINE COOLING:ENGINE
Bulletin Date: OCT 2006ECM CALIBRATION ENHANCEMENT TO SHIFTING PERFORMANCE AND SMOOTHNESS. TOYOTA. ( NHTSA ITEM NUMBER - 10020476 )5 of 5: ENGINE AND ENGINE COOLING:ENGINE
Bulletin Date: JUN 2006FUEL IN EVAP SYSTEM. ( NHTSA ITEM NUMBER - 10020123 )
JayJ is offline   Reply With Quote
Old 05-08-2007, 11:48 AM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Read this forum!!!
Old 05-08-2007, 12:01 PM   #3 (permalink)
View onsknht's Photo Gallery
Yes you're covered... EVEN THOUGH... When you bring it in for the TSBs they will tell you some garbage like, "If we cannot duplicate the issue, you need to pay labor."
Especially if you have a V6 and the Transmission Slipping Issue (cited as a "flare")... There's been a lot of issues with the V6 transmission and dealers nowadays are starting to call this characteristic "normal" and as such are blowing customers off on the issue.
To date, Toyota has only come out with one fix... Replacing the transaxle and once that's done you'll probably still have the SLIP... ooops I meant "flare."
Totally unacceptable if you ask me.
2GR-FE
onsknht is offline   Reply With Quote
Old 05-08-2007, 02:11 PM   #4 (permalink)
View toyomoho's Photo Gallery
Dealer response to complaints appears varied (good to not-so-good). Rebuilding the trans may or may not solve the issue. One owner videotaped the problem, might do the same. If no satisfaction, might post some place like YouTube.
Old 05-09-2007, 02:10 AM   #5 (permalink)
View teamtbo's Photo Gallery
JayJ,
Hmm, my 07 Camry XLE V6 had the 3rd & 4th gear shift flare but I am not convinced that what you are describing is the same problem. My car would always shift but the tach would spike about 1000rpms before it did. Are you saying your rpms will flare up but it still won't shift? That may be something different.
By the way, we had our tranny and torque converter replaced last week and so far, no shift flare. It seems to be running very well. But, we still have less than 100 miles on the new tranny so I am going to keep my eyes on it.
teamtbo is offline   Reply With Quote
