not starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2007, 01:26 PM   #1 (permalink)
View Trife's Photo Gallery
not starting
Well my car wont start, i have a 2007 LE V6 camry. about 6000 miles on it.. Windows are working, radio doesnt. I tried to start it in both N and P still no luck. Finally i disconnected the negative on the battery and it still wont work. Any clue? this ever happen to anyone else?
Trife is offline   Reply With Quote
Old 05-09-2007, 01:27 PM   #2 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
blow fuse or bad battery.
try jump start?
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 05-09-2007, 01:28 PM   #3 (permalink)
waiting for my someone to come with some cables now.. hopefully that will do it
Old 05-09-2007, 01:31 PM   #4 (permalink)
carlo$'s Avatar
if you dont hear anything at all when you turn the key it most likely is the starter fuse.
your car is too new for anything drastic.
keep us posted.
2005 LE 4 cyl
Old 05-09-2007, 01:36 PM   #5 (permalink)
View toyomoho's Photo Gallery
Suggest if under warranty, calling the dealer and asking for a tow (at their expense). This car have some kind of engine immobilizer?
Old 05-09-2007, 01:38 PM   #6 (permalink)
yea i dont hear a sound at all.. "engine immobilizer?" dont know what u talking about
Old 05-09-2007, 02:42 PM   #7 (permalink)
View DiLan's Photo Gallery
There is a chip in the key that "talks" to i guess a chip in the car without that the car won't start. That is what the engine immobilizer does(it is enabled when the "security" light flashes)
1990 Camry LE V6 25th Anniversary Edition
DONE:Sony Xplod 800W Amp(XM-1252GTR) w/ Dual Kicker Subs, Alpine CDE-102 Deck, New Eliminator Battery, Keyless Entry
TO DO:Intake adapter, fix wheel well rust
*SOLD*2007 Camry I4 SE Alpine White
http://www.cardomain.com/ride/2571595
DiLan is offline   Reply With Quote
Old 05-09-2007, 03:37 PM   #8 (permalink)
View Aceventura9586's Photo Gallery
just a thought but the new camry's don't have killswitches or fuel stop switches do they?
Aceventura9586 is offline   Reply With Quote
Old 05-09-2007, 06:10 PM   #9 (permalink)
View netman's Photo Gallery
The engine immobilizer is very sensitive as I read the manual. If you have another key ring interfering with it, it would start also.
netman is offline   Reply With Quote
Old 05-10-2007, 03:21 PM   #10 (permalink)
Gameroom cash: $303755
Did it finally start with a jump? If not, call your dealer. It's under warranty. They should tow it in and find out what the problem is under warranty. Just make sure you didn't leave a door ajar overnight leaving the dome light on or something similiar, or then it will all be at your expense.
Mike
Old 05-10-2007, 04:28 PM   #11 (permalink)
View marc780's Photo Gallery
If the engine will not crank, yeah, try a jump start, if that starts it, then take it straight to the dealer and have them fix it warranty. If this is the case, it would seem like something's drawing power when it shouldn't be and they need to check and/or fix that.
If you used the same key to start the car you've used all along, probably not the key or immobilizer device, but who knows. Whatever it turns out to be, off to the dealer it goes, i'd be thinking.
Old 05-10-2007, 04:34 PM   #12 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Mike
Mike,
My kids left the door open a few times overnight...I had no problem starting the car due to that. Unless he got a huge amp with his audio system and left the key on for so long. It could be so many things.........
Old 05-10-2007, 07:08 PM   #13 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Im thinking it may be the engine immobilizer as well. As another poster said, it's very sensitive. The manual states that it may cause the engine not to start if you have a keyring on top of the car key, or something that may be interfering with it. Try the vallet key by itself.
geoff5093 is offline   Reply With Quote
Old 05-11-2007, 11:13 AM   #14 (permalink)
sorry, but it started with a jump... I didnt leave the door open.. and even if i did i have all my lights off they dont turn on when the door is open. I dont know why it needed a jump i will take it do the dealer on my next day off
Old 05-11-2007, 01:56 PM   #15 (permalink)
carlo$'s Avatar
you need one of this:
click:
http://www.cardomain.com/ride/2379797/9
2005 LE 4 cyl
Starting Troubles on a 2005 newell1026 Archived Corolla threads 6 01-29-2007 04:33 PM
83 Corolla Not Starting ...HELP trdstarlet Archived Corolla threads 11 01-28-2007 01:19 PM
94 Lexus ES300 Starting Problem starry012 General Lexus Discussion 0 10-03-2005 01:21 PM
87 4runner not starting chronoti 4Runner Lounge 2 10-13-2004 02:21 PM
Starting problems - Electrical. pdrover Archived Corolla threads 12 02-09-2004 03:55 AM
