2004 WHEEL Width & Offset HELP?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2007, 06:30 PM   #1 (permalink)
Offset IS EVERYTHING
View str8WESTcoastn's Photo Gallery
I'm a Corolla head (86).. i'm new to the Camry scene.. I'm pickin up a 2004 Camry in less than a week and I want to put wheels on it and dump it.
The question I have is..
Whats the widest width I can go?
Whats the lowest offset I can run on different widths?
Will 18x8, 18x9, +38 offset on both work? how about 17x8, +34 offset on both??
Thanks In Advance!
str8WESTcoastn is offline   Reply With Quote
Old 05-12-2007, 08:33 PM   #2 (permalink)
View Brej's Photo Gallery
I have a '02 Camry, I am rolling on +46 offset 18's, I believe they are 8" wide if memory serves correct, as for tires, I have 235/40/18, but when I am changig tires I am going to go with 235/45/18 ope this helps
Brej
Brej is offline   Reply With Quote
Old 05-12-2007, 08:57 PM   #3 (permalink)
Yeah, it helps. Thanks
in the picture if your car on stock height with the 18's?
And do you know the stock "sleelie" size and offset is?
Any one else out there running wider than 8in?
Old 05-14-2007, 12:52 PM   #4 (permalink)
bump!
Old 05-15-2007, 08:27 PM   #5 (permalink)
rolling on stock suspension, I sized the rims based on the BBS rims which comes as the optional rim on the 02 thru 06 camry.. I got some advice from another member about some springs, which I am going to try whe next I am replacing tires...
Brej
Old 05-16-2007, 02:41 PM   #6 (permalink)
Stock is not an option!
View greylock's Photo Gallery
They won't work. I'm running 17x7 with +38 offset, TRD springs and am having rubbing issues with 225/50x17 tires. The rear fender lip is bit lower than the top of my tire and the front lips are even with the fender lip to give you an idea of the drop my car has.
Brej, looks like you might have rubbing issues if you drop your car without trimming/rolling your fender lip.
greylock is offline   Reply With Quote
Old 05-16-2007, 03:08 PM   #7 (permalink)
v6secamry's Avatar
iTrader Score: 12 reviews
View v6secamry's Photo Gallery
I am using 18x7.5 in 235/40/r18 dropped on trd springs and I do not have rubbing issues. The wheels are +38 offset
v6secamry is offline   Reply With Quote
Old 05-16-2007, 03:59 PM   #8 (permalink)
Mighty Flying Family Sedn
View Mighty~Mart's Photo Gallery
is there anyway to (decrease?) the offset w/ Stock rims? i'm plannin on adding Tein springs and thought a wider stance on the car would help it handle better...
but then again there may be issues w/ rubbing?
What do you guys think?
Mart~
Camry Gen 5 SE
2.4L I4 DOHC
Stock 16's
Totally stock
Mighty~Mart is offline   Reply With Quote
Old 05-16-2007, 06:26 PM   #9 (permalink)
Thanks for the heads up... I will really have to review my idea of lowering the car. I may consider a slight drop and stay at the 40 profile tires, but I will have to look at possibly rolling the fenders... Thanks...
Besides I would hate to loose my rims, like the white rims with the car.
Brej
Old 05-16-2007, 06:29 PM   #10 (permalink)
Brej
Wheel offset---please check--help! kemo sabe 1st Generation (1995.5–2004) 3 08-26-2006 01:28 PM
Question about wheel OFFSET !! ACV30 Camry & Solara Lounge 2 07-03-2006 04:37 AM
need some wheel offset advice bondoman Camry & Solara Lounge 4 02-01-2006 11:32 PM
2002 Sienna wheel fit 2004 Dodge Caravan? Jaspher General Discussion 1 11-18-2004 04:50 PM
91 Camry - Wheel Offset and Handling Question tvictor 1st & 2nd Generation (1983–1986 & 1987-1991) 2 11-07-2004 12:55 PM
