When you open the door and look at the bottom inside of the door where the rubber weatherstrip is, do you see little square or round holes? Those are weep holes to let water out of the door if it were to get inside, they also keep it from rusting.
The reason these are important... Do the holes happen to line up with the streaks you're seeing?
If so, then I would bet there's some grease or rust inhibitor (waxy stuff) around the holes and water going through them is washing some of it out... You'll see this for awhile until it runs out of junk in there, just keep wiping unless you want to get proactive and try to get some of it out of the hole.
2GR-FE
