Premium or Regular Gas? - Toyota Nation Forum : Toyota Car and Truck Forums
View Poll Results: Premium or Regular
Keep using Premium (93) 33 30.56%
Go back to Regular (87) 75 69.44%
Voters: 108. You may not vote on this poll
Old 05-17-2007, 10:21 AM   #1 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I've been trying out different types of regular and premium gas, but im still not sure what the best way to go is. I've been using premium for around a week now, but I dont notice much of an improvement in power (who would notice 4hp afterall?), but I seem to be getting pretty low gas mileage on premium.
I do alot of city driving, and on my old '94 Camry V6 I got around 18-21mpg when I was doing mostly city driving. On my new Camry, I filled up when I had about 3/4 left, and I only got 18.5mpg, which is horrible, considering that 22mpg is the EPA for city, while it was 17 on my '94 for EPA city. But I used my ScanGuage and on my way home I was able to get 33mpg, but I accelerated slowly, kept a consisitant speed (55mph), and didn't have to stop at all for about 10 miles.
So anyways, does using premium fuel lower the gas mileage? And is it worth using premium 93 gas when I have to fill up at least once a week?
geoff5093 is offline   Reply With Quote
Old 05-17-2007, 10:50 AM   #2 (permalink)
2003 Camry Speedster
View IPDaily's Photo Gallery
personally i don't know why you would spend money for premium when you can fill it up with 87... it's silly to spend all that extra money with no noticable improvement...
2003 Toyota Camry XLE V6, 18x7.5" ASA rims +40mm offset, Bridgestone Potenza Tires 225/45/18, H&R Sport Springs, TRD Exhaust/Strut Tower Brace/Rear Sway Bar, Wood Steering Wheel, 20% LLumar Tint
2007 Toyota Camry SE V6, Sport Leather
IPDaily is offline   Reply With Quote
Old 05-17-2007, 11:42 AM   #3 (permalink)
geoff5093's Avatar
Thats what I was thinking, I wanted to use premium for a bit to see if I noticed a difference, but I really didnt. Is the only difference between using premium and regular that premium octane gives you a tad bit more power because of the advances in timings?
Old 05-17-2007, 11:46 AM   #4 (permalink)
View raybear's Photo Gallery
It may give a little extra power, but I also noticed MPG dropped, and it wasn't because I was looking for the extra power.
raybear is offline   Reply With Quote
Old 05-17-2007, 12:33 PM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
Premium will not give you more power.
Higher octane fuel takes longer to burn and is harder to ignite. When you have a high performance engine the higher octane will allow you to run more aggressive timing, higher compression and such without pre-ignition/detonation.
A stock Camry being driven normally will not gain any performance. Granted, if the car was running really hot and you were climbing a steep mountain grade, premium fuel may get you a little more power by keeping the car out of spark knock. However, with the higher octane taking longer to burn you will likely end up with more deposits in the combustion chamber.
The point is use regular unleaded.
2006 Camry LE Special Edition
Old 05-17-2007, 01:07 PM   #6 (permalink)
View Vincenzo's Photo Gallery
He's basing it on the way some vehicles advance timing when they sense a higher octane grade. The Accord supposedly puts out additional power on premium once the computer slowly adjusts for it. I thought I kept hearing about the 2GR-FE putting out 272 on premium, but I'm not familiar with the Camry and don't have a link.
Vincenzo is offline   Reply With Quote
Old 05-17-2007, 01:22 PM   #7 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
There is absolutely no sense in feeding a car higher octane gas than what it's made to burn, because you will not receive any benefits.
Now if you were debating feeding 87 to a car that usually eats 91, that's a different story.
It's like some guys out there feeding their BMWs some special Sunoco 94 crap. LOL then they claim how their BMWs make at least 20 horses more. Pathetic fools.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 05-17-2007, 01:59 PM   #8 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The new HP ratings are based on the engine using the lowest grade fuel that the engine can burn. I know the 1MZ-FE and 3MZ-FE recommended 91 octane for best performance, but they could also run just fine on 87 with the timing retarded.
I hazard guess that the 2GR-FE is the same way. IIRC the 2GR-FE has a CR similar to that in the 1MZ-FE which recommended 91 octane. Some people with 1MZ engine noticed an increase in power and MPG when they used 91 over 87.
2007 Camry 2.4L 5M
Old 05-17-2007, 02:46 PM   #9 (permalink)
geoff5093's Avatar
From what I heard, the 2GR-FE has knock sensors which will adjust the timing slowly when you use higher octane fuel, which would give you an extra 4HP and 8ft-lbs of torque. I know the gas itself doesnt give you more power.
Old 05-17-2007, 03:49 PM   #10 (permalink)
TRD VVTi's Avatar
Gen5
No, I'm not.
I didn't know vehicles could "sense" the octane of fuel. I could also give a flying fukk about a Honda Accord.
FACT: If a vehicle is not having preignition problems, RAISING THE OCTANE WILL NOT CREATE MORE POWER!
My Formula however, DOES make more power on premium fuel. The engine and the PCM programming were DESIGNED to run premium fuel. The car runs fine without it, but has less power because of preignition which causes the timing to be retarded.
Old 05-17-2007, 04:25 PM   #11 (permalink)
The Corporate Life
GENSIXER's Avatar
View GENSIXER's Photo Gallery
premium dude she needs premium if she treats you well than give the love back i believe it makes your engine run smoother and it compliments your engine's compression ratio. but it does hurt to pay a $3.50 a gallon in L.A.
@(o.O)@ 2007 V6SE---->>
GENSIXER is offline   Reply With Quote
Old 05-17-2007, 04:46 PM   #12 (permalink)
geoff5093's Avatar
Around here regular gas runs about $2.85-$2.90, while premium runs anywhere from $3.05-$3.29.
Hess only charges $0.20 more per gallon for premium, but I heard that Hess gas isnt that good.
Old 05-17-2007, 04:54 PM   #13 (permalink)
geoff5093's Avatar
Another thing to consider is that I drive alot. I deliver pizza as a part-time job, so I put on around 50-80 miles per day. If it was a car that I used to get places, then I wouldnt have a problem using premium fuel, but since I drive so often and fill up so often im not really sure if it's worth it for me to continue using premium.
Old 05-17-2007, 05:10 PM   #14 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
hm your just wasteing your money..just buy regular and give the extra money you would spend for premium to me :p
CamrySExxx is offline   Reply With Quote
Old 05-17-2007, 05:13 PM   #15 (permalink)
Sap
sappy74's Avatar
View sappy74's Photo Gallery
In San Francisco, premium cost around $3.65 - $3.89...
Pics of my 07 Camry XLE V6
Added: SE lip spoiler, BEC105 back-up camera, mudguards, OEM moonroof wind visor, WeatherTech side window deflectors, tint 50%F/20%R, XenonDepot 6000k HID, upper/lower/fogs chrome trims.
sappy74 is offline   Reply With Quote
Unleaded premium gas in an AE101 DarkNinja75 Archived Corolla threads 4 10-01-2006 12:01 AM
Motorists urged to drive less as gas supplies drop Lord_Anarchy General Discussion 4 09-01-2005 09:29 AM
Regular gas with 2006 Corolla S? sargmel Archived Corolla threads 1 08-30-2005 07:02 AM
how to save gas 94_Toyo_Cam Off Topic 15 08-28-2005 07:55 PM
Regular or premium? kileak Archived Corolla threads 14 05-30-2002 10:24 PM
