Tire size and Brake Failure!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2007, 01:14 PM   #1 (permalink)
05_se_lunarmist's Avatar
View 05_se_lunarmist's Photo Gallery
They say you should stay within 3% of OEM size to prevent brake failure... Does this apply to both larger and smaller then OEM or is it just larger due to the extra weight?
If I was say 5% smaller then OEM, would there be any possible problems with the brakes?
05_se_lunarmist is offline   Reply With Quote
Old 05-19-2007, 01:22 PM   #2 (permalink)
View toyomoho's Photo Gallery
Larger diameter wheels place a greater load on the brakes. Imagine having wheels 10 ft in diameter and using the same brake disks, drums, etc. Smaller wheels should not be an issue.
Wrench size for brake bleeder valves stratofactor 3rd & 4th Generation (1992–1996 & 1997–2001) 6 02-10-2007 08:24 PM
Brake bleeder valve size NathanOfSeattle Camry & Solara Lounge 6 03-29-2006 07:27 PM
What size are the fittings on the brake lines.. fajkus1 Pre-88 Toyota Pickup/Hilux 1 03-16-2006 04:56 PM
Brake line size?, or what to get? toysarefun Camry & Solara Lounge 2 11-21-2004 08:27 PM
