loose foglight... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2007, 06:45 PM   #1 (permalink)
The Connoisseur
CharmCityES's Avatar
Gen5 loose foglight...
today a piece of road debris (thanks for cleaning the roads state of MD) kickd uo and smacked the driver's corner or my camry...it left only a small rubber scratch which i buffed out, but apparently my foglight took the brunt of the force and jarred loose....how would i take the figlight assy. out of the bumper and tighten it back in place?
The "Executive Sedan"
Old 05-21-2007, 06:47 PM   #2 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
Sounds like a broken bracket.
Epsilon is offline   Reply With Quote
Old 05-21-2007, 09:10 PM   #3 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
undo the plastic guards located underneath the front bumper, (to access the foglights).
then you will have access to the mounting clips/brackets that hold the fog in place and repair it accordingly.
johnnyzee is offline   Reply With Quote
Old 05-21-2007, 10:01 PM   #4 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
I had something similar happen to me. You have to drop the cover panel that is on the bottom just below the bumper to access (4 or 5 screws)
The fog light frame is the bracket. I probably should have replaced the whole light, but I just used JB weld to reconnect the piece of plastic with the screw hole in it. So far, been about 3 months, all is well and it is holding.
kenny1773 is offline   Reply With Quote
Loose Spark Plug ripsnub Pre-88 Toyota Pickup/Hilux 5 09-03-2006 08:24 PM
Loose Steering in 1997 Tacoma Gabriano 1st Generation (1995.5–2004) 16 07-27-2006 06:01 PM
Loose headlight on 94 camry? Why? How fix? green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 5 12-03-2005 11:51 PM
loose plug, where does it go (56k maybe) ryuji16 Camry & Solara Lounge 8 09-05-2005 08:47 PM
gas smell from loose fuel cap viji Camry & Solara Lounge 2 06-01-2005 09:14 PM
