'05 2AZ-FE Auto Tranny "surge" when cold. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2007, 11:04 PM   #1 (permalink)
Gameroom cash: $924700
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Ok, this just recently started to happen. the 1st 2 times, I thought it was my imagination. This time I tested it, and it happened.
When the car has a cold start,a nd is put in gear, about 10s later, there is a surge.
what happened tonight, is the car wa outside, so I needed to bring it into the garage. So I started it, put it in gear, and pulled in, and then slowly inched my way in to the back. All of a sudden, there was a slight surge where it was like there was an instant 500rpm increase. LUCKILY, I was ready, and had my foot planted on the brake. This crap ain't normal. Worst tranny I have ever driven.
Any thoughts?
~Adam
5 Lug Corolla WHAT?
Old 05-21-2007, 11:34 PM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
Adam, what was the RPM's at when u put it in gear? u know better than to try and put the car in gear when its cold, right?? lol
MrSo0h0o is offline   Reply With Quote
Old 05-21-2007, 11:39 PM   #3 (permalink)
^ Not gonna let it warm up for 5 minutes to pull it 15 feet, haha. It was the normal "cold" temp RPM.
5 Lug Corolla WHAT?
Old 05-21-2007, 11:42 PM   #4 (permalink)
MrSo0h0o's Avatar
as in.. 1500-2000rpms? if so, then thats normal for it to jump like that.. happens to me whenever i try and put it in gear when the car isnt warmed up
Old 05-22-2007, 12:19 AM   #5 (permalink)
nono, car IS in gear for about 10s. I know it does it when putting it in gear. But it;s doing it after 10s IN gear also. That is what I can't figure out. haha.
5 Lug Corolla WHAT?
Old 05-22-2007, 12:53 AM   #6 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
I know what you mean.. It's not the initial gear selection when it's cold, it's AFTER. My tranny does that once in a while even when it's at operating temp. I've found it happens more often (if not exclusively) with the A/C on. Did you have the A/C or heater on by any chance?
I sometimes wish I had a 4 speed auto. My mom's car still shifts smoother than my car despite being 10 years older than mine. It's not my car either because my aunt's 2005 Avalon with the 2GR and same tranny exhibit the same annoyances. The one redeeming factor of the quirky 5 speed auto is its low freeeway cruising RPM. Keeps engine noise down and fuel economy up.
BTW, what's the build date on your mom's Camry? Mine is 11/04 I think. My other friend with a gen 5.5 2AZ has a build date of 6/2005 and its tranny is smoother.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 05-22-2007, 01:06 AM   #7 (permalink)
Not sure on the AC/Heat. I'll cheak in the morning.
For the build date, it IS in '04. Got the car in Nov. Again, I'll check on that. I'm going to ask the dealer when I go tomorrow if there is a reprogram for the tranny. My friend's ;07 2GR is getting reprogramed this week. I'll keep you posted.
5 Lug Corolla WHAT?
Old 05-22-2007, 09:52 AM   #8 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076258
iTrader Score: 7 reviews
Gen5
Mine goes in tomorrow for the same problem, they reflashed it the first time a few months ago. but the problem is still there. I'm trying to get it all fixed while i still have my used car warrenty!
here's the thread i had about it last week. http://www.toyotanation.com/forum/t193130.html
2002 Camry SE V6 "Snow White"
19x8 +48 Offset TRD rims are Foe Sale. PM For Inquiries
Old 05-22-2007, 10:19 AM   #9 (permalink)
Let me know how it turns out!
5 Lug Corolla WHAT?
Old 05-22-2007, 11:04 AM   #10 (permalink)
Will do
Old 05-22-2007, 06:22 PM   #11 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Do this: Get in your car and start it up. Now turn the steering wheel. Notice that the RPM's will go up in response to the power steering pressure increasing.
No turn on the A/C. Notice that the RPM's will fluctuate as the compressor engages and disengages.
These things also happen if you do it while the car is in gear.
I feel it at stoplights and stopsigns all the time.
NORMAL.
2006 Camry LE Special Edition
Old 05-22-2007, 06:26 PM   #12 (permalink)
NORMAL.
mine stops jerking or hesitating when the AC is on your there's a load on the engine. when no fans are on and i slowly accellerate it jerks and the RPM's go down. It goes in tomorrow..so we'll see. I told them they better find away to fix it under warrenty cause i'm not paying them again! that and i can't afford to pay them this month..
Old 05-22-2007, 06:46 PM   #13 (permalink)
NORMAL.
The wheel was not being turned, car was straight. HVAC was off. And no, a surge forward is NOT NORMAL.
5 Lug Corolla WHAT?
Old 05-23-2007, 02:36 PM   #14 (permalink)
Gen5
So i got my car back..and it has nothing to do with the tranny..and ofcourse my used car warrenty does NOT cover it.
It needs a new EGR Valve..which they want 450 to install and 150 labour (Canadian)...i'm pissed!!!
And they charged me 90 bucks just for looking at it...but i got a car wash...90 dollar car wash? heh...
I'm not getting it done though. They said it's no big deal until my car doesn't start one day and the valve is seized up.
Old 05-23-2007, 04:11 PM   #15 (permalink)
TRD VVTi's Avatar
Gen5
^ Take the valve off and clean it. It's probably just sticking due to carbon buildup.
The diaghram may have failed but you describe it as an intermittent problem. If that's the case, cleaning it (and the port if possible) may very well fix your problem. If the diaghram was ruptured you would have the problem all the time.
I hope that helps.
Drop a manual tranny in an auto? Brake Weight 1st Generation (1995.5–2004) 13 07-06-2006 03:23 PM
95 camry auto tranny issues ziddey 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-08-2006 08:32 PM
Auto tranny having problems going into 4th machman Camry & Solara Lounge 5 12-17-2004 07:53 AM
3SGE with FE tranny Tommy Hardcore Tech and Competition 21 08-20-2004 12:39 AM
