'04 Rattles - how to remove trim? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2007, 08:14 PM   #1 (permalink)
View myrrh's Photo Gallery
Gen5 '04 Rattles - how to remove trim?
I've got an '04 XLE with two annoying rattles. One is coming from just above the clock. If I push up on the bezel, it stops.
The other is coming from the area of the assembly on the ceiling with the glasses case and reading lamps.
So, two questions:
1) Has anyone had any experience with either of these rattles?
2) Can someone please tell me how the (a) bezel surrounding the radio and clock and the (b) glasses case/reading lamps assembly are removed?
Thanks!
myrrh is offline   Reply With Quote
Old 05-22-2007, 08:17 PM   #2 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
um for the clock part you get get a flat head and pray off the panel below it with the AC , heatering and the knobs (HVAC) its just held in by clips and for the piece around the radio you would just pull on it.its also held in by clips
CamrySExxx is offline   Reply With Quote
Old 05-22-2007, 09:43 PM   #3 (permalink)
Frank20's Avatar
View Frank20's Photo Gallery
I had the rattle coming from the readling lamps also. I just pulled it out so that it is hanging on by only one clip. I stuffed some foam up there too. The rattle then went away.
CAR IS NOW SOLD
Frank20 is offline   Reply With Quote
DIY Remove Headliner Gen 4 Camry Anshu 3rd & 4th Generation (1992–1996 & 1997–2001) 17 04-25-2012 11:03 AM
TACO 05' Front-end Plastic Removal greystoke 2nd Generation (2005+) 1 02-28-2008 12:09 PM
FS: '04 Toyota Solara SLE L-TunedIS300 Vehicles 0 04-02-2006 12:32 PM
How to remove 04 Camry headlight? timkid 5th & 6th Generation (2002-2006 & 2007-2011) 3 08-20-2005 05:25 PM
04 Corolla S... How to remove taillights unioncorps Archived Corolla threads 1 01-01-2005 04:43 PM
