Clip Remover (Removing Drivers Door Panel) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2007, 08:53 PM   #1 (permalink)
Mistabullet's Avatar
View Mistabullet's Photo Gallery
(I'm trying to get rid of a mettalic rattle from my driver's side door)
I found the Engine Hood/Door PDF from www.camrymanuals.com.
From ED-15 (PDF Page 18)
5. REMOVE FRONT DOOR TRIM BOARD SUBASSEMBLY
(a) Remove the 3 screws and clip (A).
(b) Using the clip remover, disengage the 9 clips.
I was wondering what I could use instead of the clip remover or where I can find one. I tried doing this a while back but was afraid I would break the clips.
Should I just use force?
And if I were to break a clip would the local auto parts store carry these clips? Or do I have to buy a new door panel to get the clips?
Mistabullet is offline   Reply With Quote
Old 05-22-2007, 09:48 PM   #2 (permalink)
View robob2's Photo Gallery
I beleive Autozone and the like carry these.
robob2 is offline   Reply With Quote
Old 05-22-2007, 11:37 PM   #3 (permalink)
666
View 666's Photo Gallery
i removed my door panel with a screw driver and my fingers
2007 SE V6
666 is offline   Reply With Quote
Old 05-23-2007, 12:22 AM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
I've used a screwdriver on door clips for 30 years...
Old 05-23-2007, 02:19 AM   #5 (permalink)
666
i dont like using screw drivers anymore.. you can mess up the plastic if you're not careful
but yeah.. i just took out all three screws (you gotta yank off the silver plastic on the door handle to get to two of them, and then the round plastic piece where the door lever to open the door is) and that one clip where the triangle is and then i stuck my fingers under any part of the panel and yanked it out
careful not to break it though
edit: oh yeah.. roll down your window all the way first.. and then after you take off all the clips, slowly slide the panel up (it hooks on to the top of the door.. and then there are some cables and wires that you disconnect
2007 SE V6
Old 05-23-2007, 10:17 AM   #6 (permalink)
View netman's Photo Gallery
If you still want to use the Toyota clips.
I saw the clips were available at the Toyota Dealer. The other day while at the Toyota Dealer, I saw the person in front of me was able to score about 10 clips.
Didn't pay attention to the price of those though.
netman is offline   Reply With Quote
Old 05-29-2007, 09:00 PM   #7 (permalink)
Just thought I'd finish this up for anyone using the search function to find the answer.
I dealt with the 9 trim pieces by sticking a screwdriver (wrapped in black electrical tape) in the opening on the bottom of the panel. Once I loosened that first clip I took out the rest by prying the panel piece (along its perimeter) with my hand. Once you do this look back into the manual for the rest of the steps (www.camrymanuals.com).
Also, I solved the metallic rattle by tighteninga bolt, and a plastic rattle, on the other door, by tightening the screws that hold the power window & lock setup.
For Sale Brand New Camry Hybird for just $19000 cars01 Camry Hybrid 1 04-07-2007 06:00 PM
