warranty question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2007, 09:50 PM   #1 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
warranty question
ok this may be a stupid question, and im sorry if it is, but are brake pads covered under warranty?? im prepared for the flaming lol
MrSo0h0o is offline   Reply With Quote
Old 05-23-2007, 09:59 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Your Warranty Information Manual says NO!!!!!!!!!!!!!!!!!!!!!!!!!
Old 05-23-2007, 10:01 PM   #3 (permalink)
MrSo0h0o's Avatar
ahh you know you are in for it when njerald is the first to post lol
Old 05-23-2007, 10:05 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It depends on what the problem is.
Give details, you're too vague.
I have personally warranteed several sets of brake pads.
2006 Camry LE Special Edition
Old 05-23-2007, 10:12 PM   #5 (permalink)
MrSo0h0o's Avatar
well, i have 30K on the car, i bought it used at 22K and im not sure if they were ever changed(doubt it).. im not totally sure whats normal wear for brake pads.. i get some rumbling at higher speeds when i brake, could that be warrantied? just because i got new tires put on today and my mechanic said im gonna need new brake pads in a few thousand miles.. so im tryin to save as much money as possible if i can get things warrantied..
Old 05-23-2007, 10:23 PM   #6 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
Odds are, your brake pads will not be covered under warranty. Because you are the second owner, you really have no idea how the other driver drove. (Maybe they were really hard on the brakes). Plus, with 30,000 miles on the car, it is entirely likely it is due to normal wear and tear. (Maybe the previous owner drove in rush hour traffic each day).
The only case that I can see is if the pads are not wearing evenly. For example, only one of the pads is worn, while the other three are still fine. There may be other examples, but that's the only one that I can think of.
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 05-23-2007, 10:27 PM   #7 (permalink)
MrSo0h0o's Avatar
thanks for the input 98CamryLE.. i drive in rush hour traffic 3-4 times a week so it just might be in fact regular wear and tear..
side question: should i just stick with OEM pads and rotors or should i look into brembo blanks and ceramic pads?
Old 05-23-2007, 10:34 PM   #8 (permalink)
TRD VVTi's Avatar
Yeah, unless it's an actual defect in the pads or calipers it won't be covered. At those miles I doubt anybody will cover it.
If the rotors aren't warped, I'd just do a pad slap with Toyota pads. Make sure you transfer the factory shims to the new pads.
Old 05-24-2007, 12:24 AM   #9 (permalink)
View toyomoho's Photo Gallery
Rumbling can occur when braking yes. Unless something is grossly wrong, the dealer will state it is normal wear and tear.
Toyota pads work great for normal driving, much less prone to squeal and cost about the same as aftermarket. As TRD states make sure you transfer the shims, squeal issues again. Toyota rotors are also great but are much more expensive then Brembo to the point where an aftermarket choice is the way to go for most people on a budget.
You can also have the current rotors turned down on the car if enough material is left. But the cost is around the same as buying 2 new rotors and in my opinion going this route is not as good as installing new rotors.
Old 05-24-2007, 09:54 AM   #10 (permalink)
View Aceventura9586's Photo Gallery
as someone said above the only way the brakes would be covered under warranty is if there was an actual factory defect in the rotors or pads. That's one of those many things that fall under the "wear items" on your vehicle. Which means that things that are subject to wear because of driving conditions or the driver's habits, are not covered. This is why people flip out when they can't drive for shizzle and they go to the dealer for brakes and they find out its 400$ cuz they can't brake the proper way.
Aceventura9586 is offline   Reply With Quote
service work warranty question thenoeltyler 3rd & 4th Generation (1992–1996 & 1997–2001) 4 04-30-2007 12:26 PM
warranty question MrSo0h0o Camry & Solara Lounge 5 04-04-2007 03:03 PM
98 Camry 150k Diagnosis and Brake Question tallassazn 3rd & 4th Generation (1992–1996 & 1997–2001) 5 08-07-2006 12:07 AM
Warranty vs Repair Costs - Advice Needed KUMA Camry & Solara Lounge 7 06-26-2005 11:34 PM
aftermarket items and warranty bastion Camry & Solara Lounge 4 07-16-2003 09:23 AM
