Anyone with the NEW TSB applied? Or anyone with a late May build that has no FlARE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2007, 11:01 PM   #1 (permalink)
Old TN Member
View reyrey127's Photo Gallery
Anyone have the new TSB applied with the 07 CAMRY not the ES350 that has any luck without not having the flare issue? I just want this whole tranmission flare issue to be resolved. I have read up on clublexus.com and they indicate that it did not work for them, but I do not see a TSIB for the es350 out yet. I know the transmission is the same, but still, i am sure there has to be something different in software for the camry and es350. correct me if i am wrong!! Thanks all for listening.
cheers
reyrey127 is offline   Reply With Quote
Old 05-28-2007, 11:21 PM   #2 (permalink)
2007 Camry SE V6
View mrshyvley's Photo Gallery
Gen6
Originally Posted by reyrey127
Anyone have the new TSB applied with the 07 CAMRY not the ES350 that has any luck without not having the flare issue? I just want this whole tranmission flare issue to be resolved. I have read up on clublexus.com and they indicate that it did not work for them, but I do not see a TSIB for the es350 out yet. I know the transmission is the same, but still, i am sure there has to be something different in software for the camry and es350. correct me if i am wrong!! Thanks all for listening. cheers
I'm having TSB TC007-07 TCU re-flash appied to my 2007 Camry SE V6 tomorrow (Tuesday 5/29).
I'll report how it goes.
2007 Camry SE V6 Titanium Metallic, Produced 08/06 Kentucky, VIN# 4T1BK46K37U5189xx
Borla V6 High Performance Exhaust Toyota PN# 00016-32102
5/29/2007 TSB TC007-07 done - Didn't Fix Flare Problem
7/18/2007 Transaxle and Torque Converter replaced
mrshyvley is offline   Reply With Quote
Old 05-28-2007, 11:38 PM   #3 (permalink)
View Squishyface's Photo Gallery
My car was built on may 9th, I haven't noticed any transmission issues over the 150 miles I've driven it since Friday
Squishyface is offline   Reply With Quote
Old 05-28-2007, 11:40 PM   #4 (permalink)
2007 Camry SE V6
Gen6
I didn't have any problem for the first 1200 miles, then the 3rd-4th slip (flare) suddenly happened one morning as I pulled away from home.
I hope you continue to have no problems.
Old 05-29-2007, 09:33 AM   #5 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Same thing with mine, I didnt have a flare for the first 1000 miles, then sometime between then and 1500 miles I noticed a flare-up, only a few hundred RPM's though.
geoff5093 is offline   Reply With Quote
Old 05-29-2007, 02:19 PM   #6 (permalink)
2007 Camry SE V6
Wink
I just got back from having the TSB TC007-07 re-flash of the TCU in my 2007 Camry SE V6.
(for reference, my build date and VIN info are in my signature at the bottom of this page)
This is the first remedial step I've done with this transaxle, and I'm still on my original transaxle that came new with the car.
I STRESS THAT this report IS VERY, VERY PRELIMINARY BECAUSE I HAVEN'T YET HAD A CHANCE TO DO A TEST UNDER COMPLETE COLD SOAK CONDITIONS.
(I WILL DO THAT TONIGHT AND REPORT)
I did the approximately 15 minute drive from my Toyota dealer, and I didn't notice any slips (flares) at all.
The once after each engine start 3rd-4th shift slip (flare) I used to get, didn't happen this time.
I'LL REPORT BACK WITH MORE after I've taken the car out tonight after allowing it to cool off completely.
Old 05-29-2007, 02:24 PM   #7 (permalink)
Old TN Member
i pray that it works.. i really am praying.. thanks for the updates...
Old 05-29-2007, 06:37 PM   #8 (permalink)
Si no moar!
jaysi09's Avatar
View jaysi09's Photo Gallery
my 01/07 built camry with 63xx miles hasnt experience any flares so far. and i did notice that most people that had experienced the flare already are from the east coast side.
jaysi09 is offline   Reply With Quote
Old 05-29-2007, 10:12 PM   #9 (permalink)
2007 Camry SE V6
Thumbs up
Just to add, that I just got back from doing the first cold start test of the TSB TC007-07 re-flash.
It didn't slip (flare) at all that I noticed.
So far so good.
Old 05-30-2007, 03:02 PM   #10 (permalink)
Old TN Member
thanks for the information.. now can you please drive 2000-3000 miles and let me know what happens... i would prefer it if you did it like in 2 days...
i am j/k. thanks for the updates... lets pray this fixed the infamous flare issue.. now what we need is a late may or june build v6 to see if the problem persists in those vehicles as well. thanks alot...
Old 05-30-2007, 03:16 PM   #11 (permalink)
LEmon V6
View Midnight2's Photo Gallery
Sorry, but it did not fix mine. I had mine done in Dec. and on my way back from lunch today, it flared twice.
Midnight2 is offline   Reply With Quote
Old 05-30-2007, 03:24 PM   #12 (permalink)
Old TN Member
hi midnight,
the TSB was not issued until May, it could not have been done in dec. this is with the new TSB... regarding the reflash of the cpu. there is a NEW TSB out that recently came out may 17th. please make sure you had that TSB done. and this is refering to the v6 engine. thanks. let me know if this is the case. thanks for your info.
Old 05-30-2007, 03:26 PM   #13 (permalink)
summerwind's Avatar
Gameroom cash: $448930
View summerwind's Photo Gallery
Humm...
The TSB we are talking about is the updated firmware flash issued May 17, 2007
You might want to have the firmware flash done and see if it helps if what they did in December didn't solve your problem
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is offline   Reply With Quote
Old 05-30-2007, 03:28 PM   #14 (permalink)
Old TN Member
Originally Posted by summerwind
Humm...
right on brother!!!
Old 05-30-2007, 03:35 PM   #15 (permalink)
View compfreak's Photo Gallery
Same here, our Camry V6 was built around 01/07 (At least that's when it was on the lot). Have around 500ish miles right now, no flare.
PS: I personally think that location shouldn't play a role in this issue. Most of the Camrys come from either Japan or KY. It's not like the West Coasters are getting their Camrys from Japan while the East Coasters are getting theirs from KY (Or vice versa). Though....i'm also on the West Coast
compfreak is offline   Reply With Quote
Tsb Tc002-07 mrshyvley 5th & 6th Generation (2002-2006 & 2007-2011) 217 05-19-2007 10:07 PM
TSB Question BOBfromNJ 5th & 6th Generation (2002-2006 & 2007-2011) 5 04-25-2007 07:07 AM
Update and Question on the new TSB for Flare Problem atirevold 5th & 6th Generation (2002-2006 & 2007-2011) 2 02-20-2007 07:10 PM
Anyone with a late 09/06 build or 10/06 build 07 camry v6? reyrey127 5th & 6th Generation (2002-2006 & 2007-2011) 23 10-23-2006 07:13 PM
Crappy Fender Flare Paint TSB? Royalchoppers 2nd Generation (2005+) 11 06-09-2006 12:48 PM
