07 camry Radio buttons too bright !! Here is a fix - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2007, 03:28 AM   #1 (permalink)
Eyekutr's Avatar
View Eyekutr's Photo Gallery
Gen6 07 camry Radio buttons too bright !! Here is a fix
If you have enough patience, you can do this. Open up the radio and put black touch up paint on 3/4 of the surface area of each LED along the side, there are 4 each side. This is a pic with 1/2 done and it was still a bit bright. so I opened it up again, it takes time, and lots of patience. Worth it though , maybe. If you are smarter than me, you can find the illumination wire back there (green/silver) harness/connector closest to driver, wire closest to driver again....up top (above blue/yellow wire) and stick a pot or resistor or whatever the heck....As for a/c lights, dont bother, it is almost impossible.
11 Sienna XLE / 07 Camry / 06 GS300 / Retired from service 04 GX470
Eyekutr is offline   Reply With Quote
Old 05-29-2007, 12:18 PM   #2 (permalink)
Bootyologist
View 2k4CamThrilla's Photo Gallery
crazy question, couldn't someone just dim the lights lil bit?
www.myspace.com/djkraz
2009 Toyota Camry SE-(BLK LEATHER,NAVI,Debaged,Blue LED shifter mod,20% Tint)
2004 Toyota Camry LE(SOLD)
1989 Ford Tempo AWD(SOLD)
2k4CamThrilla is offline   Reply With Quote
Old 05-29-2007, 12:25 PM   #3 (permalink)
Eyekutr's Avatar
Sure, only problem is that the dimmer dims the dash (speedo/instrument cluster) also, so to make the radio tolerable, you need to really crank the dash lights down too low ....I will try to get a pic of the effect tonight, I spent WAAAAYYYYY tooooo long f*ing with that thing last night
Old 05-29-2007, 12:29 PM   #4 (permalink)
View R07M's Photo Gallery
you must have really sensative eyes, Even set on the brightest, my stock stereo wasn't too bright for me at all. And if you set it so it dims with the headlights, it's perfect for me.
2007 Camry LE : Blue Ribbon
R07M is offline   Reply With Quote
Old 05-29-2007, 12:47 PM   #5 (permalink)
View DiLan's Photo Gallery
Any1 else notice when you use the dimmer that the text/screen on the CD player flickers? Or is somethign just screwed with mine :|
1990 Camry LE V6 25th Anniversary Edition
DONE:Sony Xplod 800W Amp(XM-1252GTR) w/ Dual Kicker Subs, Alpine CDE-102 Deck, New Eliminator Battery, Keyless Entry
TO DO:Intake adapter, fix wheel well rust
*SOLD*2007 Camry I4 SE Alpine White
http://www.cardomain.com/ride/2571595
DiLan is offline   Reply With Quote
Old 05-29-2007, 01:17 PM   #6 (permalink)
Eyekutr's Avatar
I did not mind it too much, I bought the car for my dad, he had cataract surgery and is susseptible to glare...it bothered him. if you do a search there is about 6 threads on the thing being too bright for some, it is pretty bright if set at the brigthest level, point is you should not have to dim your instrument cluster sooo much to reduce the radio brightness
Old 05-29-2007, 01:18 PM   #7 (permalink)
Eyekutr's Avatar
our does not do this
07 Camry SE V6 Problem - Service Dept. Stumped - Comments? kkmatuse 5th & 6th Generation (2002-2006 & 2007-2011) 61 06-27-2009 01:45 AM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Traded in my 05' Camry for an 07' Avalon CygnusX1 5th & 6th Generation (2002-2006 & 2007-2011) 1 01-08-2007 02:28 AM
My father might buy an '07 Camry! 84Cressida General Discussion 17 08-08-2006 06:29 PM
