I need brake pads!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2007, 12:23 PM   #1 (permalink)
Bootyologist
View 2k4CamThrilla's Photo Gallery
So I go in for my regular maintenance or whatever and i usually tell them to check the brakes and tranny make sure everythign is fine...So next day (early bird) they call and tell me i need a tranny oil change, brake fluid needs to be changed, i need brake pads and resurface the rotors, and my power steering fluid needs to be flushed...Oh and my water pump was leaking but was changed under warranty...So I need some advice...I know i need brake pads, so which ones do you guys perfer? I have 40,000 on my car..2004 Camry LE.
www.myspace.com/djkraz
2009 Toyota Camry SE-(BLK LEATHER,NAVI,Debaged,Blue LED shifter mod,20% Tint)
2004 Toyota Camry LE(SOLD)
1989 Ford Tempo AWD(SOLD)
2k4CamThrilla is offline   Reply With Quote
Old 05-29-2007, 12:47 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Replace brakes, Flush Trans. Brake flush and P/S flush are not needed.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 05-29-2007, 12:55 PM   #3 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
I have 42K on my 2005 camry. will be needing the brake pad change soon too. looks like your budget may be getting high with all those items. stick to the basic for now. as was mentioned. check the serpentine belt, how is your coolant? and PVC? do the tranny drain and refill, replace brake pads, coolant. that should be all you need at 42k miles. if you have the loot then go for the best brand brakes that you can find without having to replace the rotors, like for ceramics, etc..
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 05-29-2007, 01:10 PM   #4 (permalink)
View DiLan's Photo Gallery
? ceramics need diff. rotors?
1990 Camry LE V6 25th Anniversary Edition
DONE:Sony Xplod 800W Amp(XM-1252GTR) w/ Dual Kicker Subs, Alpine CDE-102 Deck, New Eliminator Battery, Keyless Entry
TO DO:Intake adapter, fix wheel well rust
*SOLD*2007 Camry I4 SE Alpine White
http://www.cardomain.com/ride/2571595
DiLan is offline   Reply With Quote
Old 05-29-2007, 01:28 PM   #5 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
Just go with OEM pads. I never use anything but OEM components when my brakes are done because it just creates trouble later on like squaking or additional brake dust, or god knows what else.
Furthermore, unless you go with a real performance big-brake system from Brembo, you will not see any improvement in braking distance.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 05-29-2007, 02:53 PM   #6 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
hmm they suggested a tranny oil flush ? even tho it says on the dipstick you do not need to do it ...weird .. im actually going now to buy some ATF from toyota to do our Gen5.
CamrySExxx is offline   Reply With Quote
Old 05-30-2007, 05:27 AM   #7 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
I would replace the brake pads with factory pads. I would also flush the transmission fluid. As far as the power steering and brake fluid goes, it depends. There is very little failure related to not performing those services. In otherwords, it's not a bid deal at all. If it does not hurt you financially to do it then go ahead. If you don't do it, that's perfectly fine too. Don't lose a wink of sleep, it's not a big deal.
The Type T IV fluid doesn't seem to be nearly as bulletproof as Toyota seems to think it is. I've seen many vehicles with burned fluid with similar miles as yours.
2006 Camry LE Special Edition
Old 05-30-2007, 11:08 AM   #8 (permalink)
Bootyologist
How much would the brakes cost me?
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 01:32 AM
Yup, Brake Pads nodrogkam Camry & Solara Lounge 15 01-03-2006 02:09 PM
Can't find replacement brake pads for XRunner kpagel 2nd Generation (2005+) 6 12-11-2005 04:49 PM
SW20 brakes for the do-it-yourselfer ... KAOS MR2 Forum 11 09-18-2004 01:21 AM
Changing brake pads on 94 Camry JohnCWms27 3rd & 4th Generation (1992–1996 & 1997–2001) 13 12-18-2003 10:20 PM
