Adding power outlets. How to? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2007, 01:29 PM   #1 (permalink)
View MacGyver's Photo Gallery
I have a 2007 Camry XLE. It has the standard two power outlets - one in the box under the radio, and one on the console in front of the armrest. I have problems with both of those locations. I end up with cords dangling all over the place. I would like to put one inside the storage compartment of the armrest since its more convenient to keep gadgets in there while they're charging. Has anyone done this?
http://www.liquidartgallery.com
MacGyver is offline   Reply With Quote
Old 05-29-2007, 01:35 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Easy, Go buy an outlet, Wire center pin to a Positive wire, Side housing to Negative. Cut hole to mount outlet.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 05-29-2007, 01:53 PM   #3 (permalink)
Do most automotive supply stores carry these outlets or would I be better off getting it from toyota? Are there different ones or are they pretty much all the same?
Old 05-29-2007, 01:56 PM   #4 (permalink)
View DiLan's Photo Gallery
You can pick them up in most automotive stores some are cheap and some might have different styles but basically all teh same concept. Toyota might also have oem ones.
Orrr , sry just hafta do this, use a paperclip, some gum, a shoelace and a bottlecap MacGyver
1990 Camry LE V6 25th Anniversary Edition
DONE:Sony Xplod 800W Amp(XM-1252GTR) w/ Dual Kicker Subs, Alpine CDE-102 Deck, New Eliminator Battery, Keyless Entry
TO DO:Intake adapter, fix wheel well rust
*SOLD*2007 Camry I4 SE Alpine White
http://www.cardomain.com/ride/2571595
DiLan is offline   Reply With Quote
Old 05-29-2007, 02:03 PM   #5 (permalink)
View greycam07's Photo Gallery
you can always get those 3-way outlets that plug into one of your original ones. Ive done that with the console in the front and hide it with the door.
greycam07 is offline   Reply With Quote
Old 05-29-2007, 02:18 PM   #6 (permalink)
View R07M's Photo Gallery
This sounds good, I would also recomend wiring a fuse on the positive wire... just in case.
2007 Camry LE : Blue Ribbon
R07M is offline   Reply With Quote
Old 05-29-2007, 02:52 PM   #7 (permalink)
JSM1284's Avatar
^^^ Good point, I didnt mean to leave that important element out. Thanks R07M!
2005 Lexus ES330
Old 05-29-2007, 03:49 PM   #8 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
here are some ideas
http://www.cardomain.com/ride/262575/31
http://www.cardomain.com/ride/2379797/2
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 05-29-2007, 03:52 PM   #9 (permalink)
View vinniemak's Photo Gallery
I've got 4 outlets from one ; I have a 2007 CE manual and it only comes with one outlet in the dash and none in the arm rest ; I have a radar detector, Sirius satellite radio, GPS using a Dell Axim PDA and a cell phone charger....no problems what so ever...I've done my best to hide the wires as best as I can, and looks decent and very functional...will try to post a picture if I get a chance...go to Walmart...$ 12 bucks and you're all set !! no need to drill holes and screw up !!!
vinniemak is offline   Reply With Quote
Old 05-30-2007, 09:58 AM   #10 (permalink)
Thanks for all the suggestions. The electrical part of this seems pretty straight forward. Removing the various panels is always the tricky part. Getting them off without breaking them and getting them back on again can be a problem since there are ususally no instruciton for this in the owners manual and I don't want to break any locking tabs or damage the panels in the process. It seems to me that the best way to do this is to tap in through the forward wall of the arm rest storage bin to the console power outlet. Has anyone seen any photos or instructions on how to properly remove the plastic parts in this area so I can do the wiring? If not I'll just take my chances and start tugging on things ( carefully) but I just thought I'd ask.
Thanks again
Old 05-30-2007, 10:22 AM   #11 (permalink)
JSM1284's Avatar
Its easy, Just give all the parts a smooth tug, they will unhook.
2005 Lexus ES330
Old 05-30-2007, 11:47 AM   #12 (permalink)
carlo$'s Avatar
no need remove panels, just drill a small hole
in the bottom of the tray and fish with a coat hanger. run underneath side panel and splice your additional connectors.
and you can buy connectors like this:
2005 LE 4 cyl
Lexus History BLUEMEANIE General Lexus Discussion 8 11-25-2011 12:53 PM
'00 4Runner power outlets k2500guy 4Runner Lounge 0 09-20-2006 09:19 AM
J.D. Power 2006 Vehicle Dependability Study ScubaGuy 2nd Generation (2005+) 13 08-10-2006 11:38 AM
Adding Power Windows to a '97 Ando140 Celica Forum 4 07-27-2006 11:18 PM
