brand new xle out of alignment :/ - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2007, 05:23 PM   #1 (permalink)
View Squishyface's Photo Gallery
Gen6 brand new xle out of alignment :/
Got my V6 XLE on friday. Drove about 150 miles since then. It's definately out of alignment, pulls to the right. I have to have the steering wheel turned about 5-10 degrees to the left in order to compensate. Anyone else have this on a new '07?
Squishyface is offline   Reply With Quote
Old 05-29-2007, 05:49 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Yes, See my thread.
http://www.toyotanation.com/forum/t188722.html
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 05-29-2007, 06:19 PM   #3 (permalink)
View mannypeligroso's Photo Gallery
I had the same problem on my le v6.I bought it like 3 months and noticed the car pulled alot to the right.Also,my the car was heavily vibrating on the highway and felt so loose and sloppy.It felt like as if I had a hard time keeping it in center and stable.
After taking it to the dealer he found the rear allighnment was out of place.The vibration was due to the wheels being out of balance.They fixed both problems at no charge.However,I was mad at the fact that I was having such problems on a brand new car.They shouldn't be there in the first place.
mannypeligroso is offline   Reply With Quote
Old 05-29-2007, 07:04 PM   #4 (permalink)
Gameroom cash: $924700
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Happened to my friend's '05 Tacoma when he got it. Dealer just did an alignment and wheel balance and issue was solved.
5 Lug Corolla WHAT?
Old 05-29-2007, 07:39 PM   #5 (permalink)
FSCCAracer's Avatar
View FSCCAracer's Photo Gallery
When I buy a new car getting it aligned is one of the 1st things I do. More often than not its out of alignment.
07 Mag. Grey Camry SE V6 Dk. Charcoal Leather, JBL, TRD Springs, 18" R1-Racing Victory (Hyperblack) 35% Tint.
FSCCAracer is offline   Reply With Quote
Old 05-31-2007, 05:14 PM   #6 (permalink)
View marc780's Photo Gallery
If they check the alignment and it still does it, rotate your tires, radial pull is also possible. Gosh these 2007's seem to be problematic.
Old 05-31-2007, 05:20 PM   #7 (permalink)
2007 Camry SE V6
View mrshyvley's Photo Gallery
Gen6
Wasn't there a TSB concerning wheel alignment problems from the factory?
I thought I saw it some months back.
2007 Camry SE V6 Titanium Metallic, Produced 08/06 Kentucky, VIN# 4T1BK46K37U5189xx
Borla V6 High Performance Exhaust Toyota PN# 00016-32102
5/29/2007 TSB TC007-07 done - Didn't Fix Flare Problem
7/18/2007 Transaxle and Torque Converter replaced
mrshyvley is offline   Reply With Quote
Old 05-31-2007, 05:21 PM   #8 (permalink)
So I went to the dealership service department. They said it was radial pull and rotated the tires. I think it still pulls to the right, though I need to give it some more time to make sure I'm not just imagining it.
When I was at the service department, I got a little angry at the service rep that signed me in because he told me they didn't have the man power to do an alignment right then, and that I'd have to drop the car off. I was mad because I had setup an appointment for that specific service. I assumed that if you are able to setup an appointment for service, then the dealership should be able to do that service at the appointed time.
Annnnyways, I'll give it some more time and see if I can't tell whether it's really still pulling or just my imagination.
Old 05-31-2007, 08:41 PM   #9 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
I hear you about that dealership "service". I like to run every single "mechanical suspicion" through my trusty mechanic friend. All of our family vehicles have gone to him for like 10 years.
He always checks out the problem first (test-drive, inspection, etc) and recommends me what's wrong. No charge too unless I want him to do some work.
The problem with dealerships is that:
1) They always try to reproduce the problem although it might only sometimes happen. If they don't reproduce, they do NOT take your word for it, and tell you they see nothing wrong. Or that it's within tolerable specifications.
2) They just follow strict procedures instead of actually searching for the cause of the problem.
So once I have background info from my mechanic, I basically TELL my dealer what is up, what's causing, and what will fix it.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
4 wheel alignment Doctor J 1st & 2nd Generation (1983–1986 & 1987-1991) 9 03-10-2009 10:37 AM
Tire replacement and wear Texas_robert 1st Generation (1995.5–2004) 33 04-25-2007 07:24 AM
My 05 I4 XLE vs 07 V6 LE Comparison moeharri 5th & 6th Generation (2002-2006 & 2007-2011) 26 05-24-2006 09:24 PM
2005 Toyota Camry XLE CD/ tape player peterlola Audio, Video, and Security - Tech 14 05-18-2005 04:03 PM
Strut bar and alignment!!! need help Vampress Camry & Solara Lounge 17 06-28-2003 11:31 PM
