"S" mode is kind of weird if you are used to Tiptronic or other cars with a manual shift capability. Its the Toyota way don't you know..
"We know what is best for you and will allow you to shift if you are within our pre-programmed parameters"
Page 165 of the owners manual explains how it works.
You can change the shift range position in the S mode. The shift range position
can be switched between 6 (sixth range) and 1 (first range) by moving the selector lever up to the + side or down to the side.
When the selector lever is shifted to the S position, the initial shift range position is 4 (fourth range) or 5 (fifth range) depending on the vehicle speed.
However, if the selector lever is shifted to the S position when AI shifting control is being performed, the initial shift range position may be 3 (third range). This is because the suitable shift range is selected depending on the driving condition.
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
