Help: Removing the SRS door plastic cover - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2007, 12:52 AM   #1 (permalink)
View netman's Photo Gallery
Gen6 Help: Removing the SRS door plastic cover
I'm trying to install the auto-dimming mirror on my '07 Camry LE.
However, I'm having troubling removing the driver door pillar plastic covering with the SRS symbol on it.
Any help or guidance is apprecated.
netman is offline   Reply With Quote
Old 05-31-2007, 02:46 AM   #2 (permalink)
666
View 666's Photo Gallery
slip your fingers underneath and pull ?
look at the diagrams in the manuals posted in the general camry forum for our year
it shows the kind of clips that are holding it in place
i am pretty sure you can just slip your fingers underneath and tug it out
dont use a screw driver unless its covered with tape.. it will damage the plastic
2007 SE V6
666 is offline   Reply With Quote
Old 05-31-2007, 08:15 AM   #3 (permalink)
View sickstick's Photo Gallery
Canada
It's called the A pillar garnish. just my 2 cents...
Medium pimpin'
sickstick is offline   Reply With Quote
Old 05-31-2007, 10:03 AM   #4 (permalink)
Eyekutr's Avatar
View Eyekutr's Photo Gallery
BIG NOTE....it does not come off, just pries off 1/2 - 1 inch or so, it is so that airbag does not make that thing hit you in the eye !!!
11 Sienna XLE / 07 Camry / 06 GS300 / Retired from service 04 GX470
Eyekutr is offline   Reply With Quote
Old 05-31-2007, 03:06 PM   #5 (permalink)
The instruction (from Southeast Toyota) mentions something like this:
(1) Pull top of A-pillar trim out
(2) Rotate A-pillar trim retainer 90 degress and disenage from A-pillar trim.
(can't seem to be able to locate the retainer)
next step.. (never got to step 3)
(3) Pull base of A-pillar trim out towards rear of vehicle to remove.
Thanks for your suggestion..
anybody got pics. of your corolla xrs engine cover? xrs22 Archived Corolla threads 2 05-06-2005 05:15 PM
Removing Gen 2 Valve cover? PoR2GeEzCamry 1st & 2nd Generation (1983–1986 & 1987-1991) 3 03-20-2005 10:53 PM
removing engine cover unioncorps Archived Corolla threads 0 02-19-2005 01:25 PM
