I think my driver's side door sagged a bit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2007, 08:18 PM   #1 (permalink)
Gameroom cash: $232150
View Joe B's Photo Gallery
I just noticed a couple days ago my driver's side door seems to be about a quarter of an inch lower than the rear door where they meet above the handle area..
The passenger side door matches up perfectly with the back door.
Could have been like that from the start but I just noticed the small difference.
Maybe it's because that door is used more.
Anybody have the same issue?
'11 Camry Hybrid Classic Silver/Ash
Moonroof | NAV | Leather | JBL Audio | XM | Blue Tooth | OEM Remote Start | Michelin Primacy MXV4
'11 Honda CR-V EX-L w/NAV 4WD Glacier Blue/Gray
Leather | Remote Start | Fogs | Premium Sound | XM | Wood Dash | Michelin Primacy MXV4
Joe B is offline   Reply With Quote
Old 06-01-2007, 08:20 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
NO
Old 06-01-2007, 11:16 PM   #3 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
Yes I do, look http://www.toyotanation.com/forum/t195307.html
El Tano is offline   Reply With Quote
Old 06-02-2007, 07:45 AM   #4 (permalink)
Originally Posted by El Tano
Ouch!
But that was from the accident,right?
Called my buddy who is a manager of a bodyshop I use and was told he thinks that to adjust the door you have to remove the front fender to get to shim the door hinges or something.
I sure don't want Toyota doing that!
I just may live with it or have him do the adjustment.
Just another joy of an American built Toyota.
Old 06-02-2007, 09:42 AM   #5 (permalink)
El Tano's Avatar
yes, I was jocking..
Remove the fender to adjust door????? It has to be another way (I think)..
Tell the dealer to adjust it...
Old 06-02-2007, 09:51 AM   #6 (permalink)
If I decide to do anything,I'll use my body guy.
Last thing I want is the dealer doing body type work.
The fender off to adjust is possibility according to him.
He wasn't sure.
Something about getting to the hinges to make the adjustment.
He's a good friend who I know isn't pulling my middle leg.
He won't even charge me but I'll throw him or his kids something.
Old 06-02-2007, 10:38 AM   #7 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Mine is exactly the same, although I think it's less then 1/1 of an inch. I know when I look in my driver side mirror, I can see that the chrome trim and curves dont line up exactly. It's not that way on the passenger door though.
geoff5093 is offline   Reply With Quote
Old 06-04-2007, 07:43 AM   #8 (permalink)
You have the issue,too.
Yeah it's about a quater inch but is noticeable and the passengerside door is perfect.
I gues because it's opened much less..
Anyone else?
Old 06-04-2007, 09:07 AM   #9 (permalink)
View onsknht's Photo Gallery
Anyone else?
Pretty common early on... My SE driver's door was low too. The ES350 guys were the most vocal about it, nobody here seemed to notice. In my case it was very noticable to me because I could see the moulding didn't line up looking down the side through the mirror...
I never had it fixed, but the top window frame was up as tight as it could be to the roof, this led me to believe either...
1. The car was bent
2. The driver's door was built wrong, the window frame was assembled too high on the driver's door.
I wanted to but never did get some measurements, cause I think #2 is more likely the case.
2GR-FE
onsknht is offline   Reply With Quote
Old 06-04-2007, 09:14 AM   #10 (permalink)
1. The car was bent
I have a 6/06 build.
Seems to be a pretty common issue if it's both here and on the Lexus forum.
I'll check and see with my buddy is it's an easy adjustment or not.
Good point on the tightness to the roof.
Could be another issue if adjusted correctly.
geoff5093 just got his '07 and has the issue so it may be a factory defect versus door sag.
Just doesn't make sense as the passengerside door is perfectly aligned.
Old 06-04-2007, 11:02 AM   #11 (permalink)
Yup, it's not sag, can't be... Mine was an 09/06 build and it "sagged" the day I brought it home.
Seriously, there looks to be no room at the top of the door to even make it straight... that's why I'm thinking the jig used to make the driver's doors is wrong casing the upper window frame to be installed too high on the door... To fix it right it looks like the window frame needs to be cut off then shaved 1/8-1/4 then reinstalled so that the door can be adjusted up... It's really weird that's for sure, just look at all the other tolerances around the door, if you adjust it in any other direction those will be off.
2GR-FE
Old 06-04-2007, 11:13 AM   #12 (permalink)
Thanks for the info.
I think I'll just have to live with it.
Must be a lot of '07's out there with this issue.
I was just thinking...I wonder if that trim can be raised that 1/8-1/4 inch toward the end to make up the difference?
Like maybe tapped up a bit?
Old 06-04-2007, 11:31 AM   #13 (permalink)
geoff5093's Avatar
I noticed it probably a couple days after I got the car. It was probably there before, but I just didnt notice it.
Heres a pic, is this what it looks like for you guys to?
Old 06-04-2007, 11:34 AM   #14 (permalink)
Geoff,yours is actually higher than the back door.
Mine is about the same distance off but the front door is lower.
You might be able with a small block of wood and rubber mallet or hammer tap the trim down to line up with back door.
Old 06-04-2007, 12:09 PM   #15 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
Shit that's not looking good. The problem is that the door alignment (as well as hood/trunk) is such a sensitive thing that after something happens, it might not be the same again.
The door defintely looks different.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
07 Camry: Driver's side B-pillar rattle revisted proteus220 5th & 6th Generation (2002-2006 & 2007-2011) 7 06-01-2007 11:18 PM
drivers side windows cexsiman 1st Generation (1995-1999) 5 04-20-2007 01:35 PM
Water Leak - Driver's Side - 1991 PU Xtra Cab 2WD Toyota-fan 89-95 Toyota Pickup/Hilux 10 03-26-2007 12:34 PM
PW on drivers side won't move jpjahn Camry & Solara Lounge 6 06-29-2006 02:57 PM
gen 3 : my automatic lock button on my drivers side doesnt work???helpppp TheGhostCamry 3rd & 4th Generation (1992–1996 & 1997–2001) 1 10-21-2005 09:00 PM
