Factory Fog Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2007, 12:32 PM   #1 (permalink)
MyCar_SE's Avatar
View MyCar_SE's Photo Gallery
Gen5 Factory Fog Lights
How do you go about changing the fog light bulb?
MyCar_SE is offline   Reply With Quote
Old 06-06-2007, 01:19 PM   #2 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
iTrader Score: 7 reviews
if you look under you car, there's a black plastic piece protecting the underside. Undo a few or all of the screws, let the piece drop down, then you twist and pull like a normal headlight bulb. Remember not to touch the bulbs! Or if you want you can pull the bumper off! I pulled mine off when i did my headlights and that was an easy access to the foglights..but i wouldn't suggest doing that JUST for one foglight..Hope this helps
2002 Camry SE V6 "Snow White"
Old 06-06-2007, 02:23 PM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
If you have small and long arms you can reach behind the bumper with the hood open and change them. Otherwise yes (and most likely), you will need a 10 mm wrench/socket and a screw driver to remove a few bolts and clips for the panel behind the bumper under the car to gain access.
2006 Camry LE Special Edition
Old 06-06-2007, 02:36 PM   #4 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
you may have to make your own little harness. click link.
http://www.cardomain.com/ride/2379797/14
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 06-06-2007, 03:02 PM   #5 (permalink)
TRD VVTi's Avatar
Not if you use the correct bulb.
Old 06-07-2007, 02:17 AM   #6 (permalink)
MyCar_SE's Avatar
wow.. i gotta take off the black plastic piece... that's probably better than trying to reach down there.. i don't have small hands
Old 06-07-2007, 08:57 AM   #7 (permalink)
It'll take all of 10mins
Old 06-07-2007, 09:40 AM   #8 (permalink)
carlo$'s Avatar
buy your bulbs at wallmart, 4.95 each. if you buy them
at the dealer or somewhere else they will be very expensive.
better to buy at wallmart (generic) and make you own little harness.
they are H3 55 watts.
2005 LE 4 cyl
Old 06-07-2007, 09:54 AM   #9 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
^Why not just buy the 9006 bulbs and put them in there? After all, the plug is designed for 9006 bulbs and they aren't terribly expensive. Why would you make a harness when you don't have to? The H3 bulbs shouldn't even fit in the fog light and I think they are inferior to 9006 bulbs.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 06-07-2007, 09:57 AM   #10 (permalink)
^ i was just about to type that myself, but was just double checking the number lol
Old 06-07-2007, 10:22 AM   #11 (permalink)
TRD VVTi's Avatar
Gen5
No kidding.
This kind of crap happens all the time. If you don't know what you're talking about JUST SHUT THE *%$# UP!
Old 06-07-2007, 10:40 AM   #12 (permalink)
carlo$'s Avatar
my mistake. i guess the stock fog lamps dont use H3 bulbs.
2005 LE 4 cyl
Old 06-07-2007, 08:32 PM   #13 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
i would suggest lifting the front end of your car up to make things easier. some of the clips for the splash guard are far underneath the car... i don't know about you, but i don't fit underneath the car that easily
and yes, OEM and OEM style fog lamps use 9006 bulbs.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 06-07-2007, 09:29 PM   #14 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
what i do to get to the fog lights, drive my car up my ramps(not necessary but it helps), undo the 3 screws in the corners near the foglights.. and then u should be able to pull out the black piece enough to get a visual on the bulb location and slide your hand in to replace them..
MrSo0h0o is offline   Reply With Quote
Old 06-08-2007, 03:03 AM   #15 (permalink)
View jaep0913's Photo Gallery
damn... i want fog lights...
jaep0913 is offline   Reply With Quote
Fog Lights on Hybrid Key-on-ee Camry Hybrid 8 12-10-2006 11:12 PM
Fog Lights with Squirrel Finders? thapranksta 5th & 6th Generation (2002-2006 & 2007-2011) 2 10-21-2006 11:57 PM
Fog lights Samk Camry & Solara Lounge 20 12-26-2005 09:48 PM
