E85 gas in a 2007 camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2007, 04:32 PM   #1 (permalink)
King Charles
View cpearson73's Photo Gallery
Has anyone done it, is it any good, bad, for the car? Just curious, cant afford gas these days and I have an I4.
cpearson73 is offline   Reply With Quote
Old 06-08-2007, 04:33 PM   #2 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
I think only "FlexFuel" engine-equipped cars will run on that. Well, that's not to say that the Camry won't. But long-term effects are likely negative.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 06-08-2007, 05:51 PM   #3 (permalink)
FSCCAracer's Avatar
View FSCCAracer's Photo Gallery
Vehicles designated E85 compatable have different seals in them - they withstand the acidic deposits that E85 generates during combustion. Basically it will eat the rubber, aluminum and magnesium in your engine - slowly. Don't do it man! I do use 10% ethanol blend when driving in the upper midwest.
07 Mag. Grey Camry SE V6 Dk. Charcoal Leather, JBL, TRD Springs, 18" R1-Racing Victory (Hyperblack) 35% Tint.
FSCCAracer is offline   Reply With Quote
Old 06-08-2007, 06:30 PM   #4 (permalink)
2007 Camry SE V6
View mrshyvley's Photo Gallery
Gen6
Anyway, it makes no economic sense to use E85 in your car.
When you do the energy calculations of E85 vs gasoline, when gasoline is for example $3.00 per gallon, E85 would have to cost about $2.20 a gallon to break even.
How often do you see that large of a price break between the two at the pump?
Also, your cruising range per tankfull will be reduced.
2007 Camry SE V6 Titanium Metallic, Produced 08/06 Kentucky, VIN# 4T1BK46K37U5189xx
Borla V6 High Performance Exhaust Toyota PN# 00016-32102
5/29/2007 TSB TC007-07 done - Didn't Fix Flare Problem
7/18/2007 Transaxle and Torque Converter replaced
mrshyvley is offline   Reply With Quote
Old 06-10-2007, 09:57 AM   #5 (permalink)
View Aceventura9586's Photo Gallery
By the way, tests have been done that showed the ethanol has about a 27% decrease in MPG.
Aceventura9586 is offline   Reply With Quote
Old 06-10-2007, 10:48 AM   #6 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
An email to Toyota should probably be generated to answer this question. You certainly don't want to be the first one to try it and then discover it ate the seals out and Toyota refuses to warranty their replacement.
gdanaher is offline   Reply With Quote
Old 06-11-2007, 01:40 AM   #7 (permalink)
View netman's Photo Gallery
I don't think your vehicle can handle it.
Check with Toyota Customer Service Center first.
http://www.toyota.com/about/contact/index.html
Just curious, let us know what you find out also.
netman is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
2007 Toyota Photos Help! Autoboy Off Topic 7 01-03-2007 09:55 AM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 06:27 AM
2007 Camry Unveiled...CheckOut My Pics LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 31 01-10-2006 04:05 PM
