Originally Posted by DoubleTake85
Anybody??
there are several threads that have detailed instructions on how to take apart a door... if you are not sure go to a book store, pick up a haynes manual and flip through it, or try and down load a service manual...
to be honest with you, it is pretty straight forward... generally there are screws and clips that hold the door in place... remove screws, gently tug on door until the clips release... you might break a clip or two in the process, buy replacements at toyota...
when you get all the screws out, and the door panel is ready to come off, you will notice that it is connected via a wire to the door..
in other words... that is the connector that everyone is talking about, try unplugging and plugging it back in... and check to see if that works with your keyless lock and unlock function...
if that doesn't work, try using a volt meter on the wires themselves... if you have power, then the wires are good, if no power, than replace wires...
if you do have power, and still no locky... then you are down to two choices.. 1. your switch is bad, or 2. it could be your actuator
now here is where it becomes a pain in the ass... you can take apart the other door, the door that works, remove the switch from it, plug it into the door that doesn't work, and try the remote again... if it works... then it's a bad switch, if it doesn't work, its a bad actuator...
if you are not sure what an actuator is... google it... wiki it, there are lots of explanations out there...
and someone correct me if i'm wrong...
edit: you can also try johnnyzees method, never tried that myself...
