seal it!
If its not in a noticeable location, like on the underside of the bumper, I would sand it down, clean it real good and use some clear spray paint to seal it. Use several coats for good measure (be careful of overspray or you'll be clay baring ur ride for hours!). That's what I would do, spend $5 as opposed to $200! Although, if it's something that can be seen, I would definitely take it to a body shop, but then you run the risk of color matching not quite right!
Good Luck
BigWillie
2007 Camry LE I4 Auto - Magnetic Grey Metallic / Bisque cloth..............Live Free or Die!
