Does anyone know how to calculate optimum PSI? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2007, 02:07 AM   #1 (permalink)
I callz it like i seez it
View ScrooYoo's Photo Gallery
Anyone know a method to calculate this? gen 5, 17x7.5 rims, 225-50-17 tires.
ScrooYoo is offline   Reply With Quote
Old 06-11-2007, 05:17 AM   #2 (permalink)
View R07M's Photo Gallery
Optimum PSI can vary depending on how soft or stiff you want the ride. Your tire should have "recomended" PSI imprinted on it, that oc course may not be optimal for your style of driving.
2007 Camry LE : Blue Ribbon
R07M is offline   Reply With Quote
Old 06-11-2007, 07:39 AM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
More lousy info!!!!
The MAXIMUM pressure is on the tire!!!!!!!!!
Old 06-11-2007, 08:17 AM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
Originally Posted by njerald
More lousy info!!!!
Agreed!
I would run between 30 PSI and the maximum PSI on the side of the tire.
I would run the most you can and still have ride comfort. That will help achieve the best fuel mileage and the least amount of wear on the tires.
2006 Camry LE Special Edition
Old 06-11-2007, 09:06 AM   #5 (permalink)
More lousy info!!!!
How is that lousy info? my post said: "Your tire should have "recomended" PSI imprinted on it"
EDIT: never mind, didn't read your whole post. So if the maximum is on the side of the tire I did have lousy info.
EFIT 2: Even if it was lousy info, doesn't justify you beening an asshat about it....
Old 06-11-2007, 09:18 AM   #6 (permalink)
TRD VVTi's Avatar
^ Yes it does. You shouldn't be passing information on to others that is incorrect. If you don't know what you're talking about let someone who does answer the question.
Old 06-11-2007, 09:21 AM   #7 (permalink)
Well, there is a way to correct someone without being an ass.. really, try it... After looking at your other posts, it'll be really tough for you...
But if you really want me to admit it, fine... Your e-penis is bigger than my e-penis... there, happy?
Old 06-11-2007, 09:22 AM   #8 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
EFIT 2:
and you spelled EDIT wrong
no, but really ... i would go just under the Max. PSI indicated on your tire ... i dont care much for ride comfort (anything PSI is comfy enough for me ... even when i was driving with my old tires and one had a slow leak)
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-11-2007, 09:32 AM   #9 (permalink)
TRD VVTi's Avatar
Nobody was being an asshat. You don't need to cry.
Old 06-11-2007, 09:40 AM   #10 (permalink)
Nobody was crying. You don't need to be an ass. but whatever
Old 06-11-2007, 10:24 AM   #11 (permalink)
TRD VVTi's Avatar
Gen5
You're whining because someone said this:
More lousy info!!!!
He wasn't being an asshat. njerald said it was lousy info, and IT WAS. He also said it's the maximum pressure that's on the side of the tire and IT IS. Nobody called you names, was rude to you, or such. You were just corrected.
Old 06-11-2007, 11:00 AM   #12 (permalink)
2007 Camry SE V6
View mrshyvley's Photo Gallery
Gen6
One thing I would add is, I always keep an eye over time on tread wear.
If for example, the tires appear to be wearing a little more in the center than around the edges, I run a slightly lower pressure.
If they appear to be wearing less in the center, I raise the pressure slightly.
All this while keeping in the neighborhood of the recommended tire pressure printed on the tire.
2007 Camry SE V6 Titanium Metallic, Produced 08/06 Kentucky, VIN# 4T1BK46K37U5189xx
Borla V6 High Performance Exhaust Toyota PN# 00016-32102
5/29/2007 TSB TC007-07 done - Didn't Fix Flare Problem
7/18/2007 Transaxle and Torque Converter replaced
mrshyvley is offline   Reply With Quote
Old 06-11-2007, 11:27 AM   #13 (permalink)
one more thing then I'm done...
1) I admitted it was lousy info
2) I have no problem being corrected. Just the tone that was conveyed while I was being corrected. Now maybe there was no condescending tone inteneded, but that's what I feel was conveyed through his response, not just to me, to many other posts he replies to. Considering he actually admitted to being rude about it, he was trying to convey a condescending tone.
no problem though, I'm over it.
Old 06-11-2007, 04:03 PM   #14 (permalink)
TRD VVTi's Avatar
Those are great tips!
I've never seen a Camry wear the tires in the center buy your advice is sound. That's why you're better off with a little more air, than not enough.
Old 06-11-2007, 05:08 PM   #15 (permalink)
2007 Camry SE V6
Gen6
I really haven't seen it on a Camry either, but that's just a general thing I've always done.
If one is going to experiment with air pressures, it just seemed like something to watch out for just in case.
It does make a difference on some vehicles.
Custom sc for 4agze bsee Archived Corolla threads 21 08-31-2007 01:31 AM
URD supercharger is here!!!! Chipper57 2nd Generation (2005+) 48 05-04-2006 05:06 PM
How to make a 4-5 psi wastegate actuator! 97camryman Camry & Solara Lounge 8 04-17-2006 06:22 AM
Body & Boost MR2-Good-4-u MR2 Forum 11 10-25-2005 01:09 PM
Hyde's New Dyno JekylandHyde MR2 Forum 1 07-25-2004 09:33 PM
