For V6's is there a difference between S and D? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2007, 07:01 PM   #1 (permalink)
View jasongg06's Photo Gallery
Hey guys, i know that you can shift the auto when you put it in S mode. If you put it in S mode and you don't use the shifters, what does it do? Is the shift patterm different from D? thanks!
jasongg06 is offline   Reply With Quote
Old 06-11-2007, 07:04 PM   #2 (permalink)
Mistabullet's Avatar
View Mistabullet's Photo Gallery
Think of S as a gear limiter. For example, if you leave S on 4th gear then your automatic tranny will only use the first four gears. It will not shift above 4th and will only hit the rev limiter if attempt to push it beyond 4th gear.
Mistabullet is offline   Reply With Quote
Old 06-11-2007, 07:19 PM   #3 (permalink)
ooh
so if i put it in S and leave it on 6th then it will shift exactly like d? or is the shifting more aggressive?
Old 06-11-2007, 07:22 PM   #4 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Gen6
It doesn't work like the old overdrive button. The shifting will be the same.
gdanaher is offline   Reply With Quote
Old 06-11-2007, 07:30 PM   #5 (permalink)
ah i c
thanks u guys
Old 06-11-2007, 08:01 PM   #6 (permalink)
Originally Posted by jasongg06
ooh
It will shift exactly like D. You can always make it agressive by going through the gears yourself, and watch out for the redline.
