Is it the pulley or the belt that is squeaking? Firstly, DO NOt use belt dressing on it - this stuff is a petroleum base product and will eat your belt in a couple of weeks. (I found this out the hard way and so I dont use it any more!).
Use some silicone spray, or armor all gel on the belt. If the squeak goes away, maybe its time to change the belt.
If squak does not go away, shut off the engine and spray some oil or tri flo or other lubricant on ONE pulley bearing at a time. (You are not trying to lubricate it -cause you cant anyway, those bearings are sealed-, you are just trying to isolate the squeak).
then when the squeak goes away you've found the problem part to change.
