Poor grounding point. That is almost certainly your cause especially if you're running an aftermarket audio in there.
If you're confident that your ground point is proper, then lower the input gain on your aftermarket amp. That will decrease and eventually remove all interference.
I have done a custom audio job on my old car. I had two amps in there. The car was a Toyota Echo (also 4 banger) and I had the symptom which you describe.
I fixed it through:
1) Purchased a higher-end Pioneer head unit which had 4V preouts instead of 2.2 as most have. This gives out a stronger signal.
2) I decreased the input gain on my speakers amp (the sub amp was fine).
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
