k after reading, i figure some photos are needed heh.
went out and took some pics
my new cutoff, i reaimed my headlamps because when I got someone to drive in front of me, through their rearview mirror, the driver side looked more blue then the passenger side because the cutoff on the driverside was higher and the colour part of the cutoff was creating the look that the lights were aimed up and down
same cutoff, but with the car further away from the wall
picture of the lights hitting the ground
strange 'flower pattern' i have in the driverside projector, only shows when the lights are on,
same cut off picture as the first two
pic of the lights hitting the ground from the point of view of inside the car centre, as you can see from the red line i drew the driverside lights hit the ground a bit before the passenger side.
same cutoff pic but with the car about 1.5 metres from the wall
