Originally Posted by jaep0913
how was installing the fog lights ?
Fog light install on a scale of 1 (easy) to 10 (hardest) are about a 6. Drilled a small hole big enough to pass the blade of a jigsaw, then made a rought SMALL cut. Measured and then cut again and repeat until the fit is snug.
Wiring was already there, now im working on finding a stock turn signal with fog light control, so that it all works stock, unfortunelatly the trigger from the steering colum is not a constant 12V. If you but the kit with wires then just run them and save yourself this hassel.\
