Questions about an HID Retrofit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2007, 12:25 AM   #1 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Gen6 Questions about an HID Retrofit
I've read through many threads both at HIDPlanet and a few HID threads here.
I have purchased Philips LVQ212 ballasts and Phillips 85122+ burners. The car would be an 07 Camry SE with stock halogen projectors.
I am either considering to do the retrofit now, or just mod my stock projectors to fit the D2S bulbs.
If I do decide to do a retrofit, I would have no idea how. From my understanding, a retrofit is removing my stock projector by dremeling it off and using an HID projector, ie s2k or TSX, and putting it in. I don't quite know how I would make the new projector fit, via just epoxy or some type of mounting screws? I have absolutely no idea in terms of a retrofit knowledge, that's probably one of the reasons why I'm debating wheter to retrofit or not.
If I do retrofit, what would be a good projector to choose from. I've found that the sizes of the stock projector is a length of 5.75", width of 4", height of 4.25", and diameter of the lenses is 2.25". S2K projectors can go for upwards of $300, while TSX ones are only around $120 or so. Is there a huge difference between the two? Any other recommendations, would TL projectors fit?
Thanks for all the help, this would be a fairly confusing mod for me to do by myself, but I want to do it right.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 06-22-2007, 12:33 AM   #2 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
You wouldn't be dremelling off the old projectors. You would be opening up your headlamps, and I'm sure the old projector is simply held on by a few screws. Once you take that out, you need to find a way to make an HID projector fit... generally, you would drill holes either in the housing or in the reflectors (which in this case you don't have), and mount the projector with screws.
There is no clear-cut way to do a retrofit-- every retrofit is unique and custom. I might have the same projector/bulb setup as another person, but I can guarantee you that the ways that we mounted our projectors are very different.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 06-22-2007, 12:44 AM   #3 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
S2K projectors FTW!
Epsilon is offline   Reply With Quote
Old 06-22-2007, 12:54 AM   #4 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
Anything can fit. You just have to find a way. Some are just easier to fit than others. There's a guy on here that put TL projectors in a Gen 5. He had to remove some of the bottom of the reflector but (I think) it all worked out at the end.
And as Epsilon said, the S2K is a stronger projector than the TSX and it has a sharper cutoff line. The S2K is one of the hardest projectors to retro. The TSX is one of the easiest projectors to retro. The S2K is significantly costlier than the TSX. At the end, it is up to you.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 06-22-2007, 01:01 AM   #5 (permalink)
Epsilon's Avatar
The TL Bi-xenon projector is known for its great output both low beam and high beam wise. But that output can be bettered 10 folds by swapping the factory lens used for the projector with a pair of clear lenses from the ZKW bi-xenon projectors. The ZKW units are very rare because they are only found in one car, the 04 BMW 330XI. Due to this rarity the units run from $350 to $450 depending on the condition of the projectors. The result is output is crisp and clear, The cut off line gets razor sharp, and you get crazy blue color on top of the cut off line.
Old 06-22-2007, 01:26 AM   #6 (permalink)
View TitaniumSE's Photo Gallery
^ I don't see the pics..haha.
TitaniumSE is offline   Reply With Quote
Old 06-22-2007, 01:36 AM   #7 (permalink)
2GR FTW
darksparkz's Avatar
Hm, I don't think I'll be doing the s2k projectors due to the high prices on them.
I know TSX is considered to be one of the best bang for buck projectors to get. Any opinons on TL ones or E46s?
I don't think a bi-xenon projector would work correctly for me, due to the 07 Camry has seperate high beams and low beams, 9005 for highs and H11 for lows.
Old 06-22-2007, 03:15 AM   #8 (permalink)
HID/Retrofit Expert
Well, TLs are bi-xenon. I think they might be a bit too big for the Gen 6 housing.
But I'd say in overall output... S2K > TSX = TL > e46 ----- what I meant there is that the TSX and TL have very similar outputs, but one is single xenon, and one is bi-xenon.
Old 06-22-2007, 07:14 AM   #9 (permalink)
Francois L'Ollonais
lollonais's Avatar
View lollonais's Photo Gallery
This might be an off question or already discussed, but does lexus have any HIDs? if they do, would those fit better since they are the same company. Also, why would Toyota make the camry with projectors and not give the option of HIDs.
2007 Black Camry CE
20% Black tints, Prestige Alarm with Solenoid for Trunk
2009 Pearl White Highlander Hybrid Limited
Navigation Package OEM everything except overhead DVD
lollonais is offline   Reply With Quote
Old 06-22-2007, 10:36 AM   #10 (permalink)
2GR FTW
darksparkz's Avatar
I don't think it would be any much easier to put Lexus projectors in. I've heard good things about both RX330 and LS400 projectors though.
Yeah, I wish the Camry had an option for HIDs or something at least.
Looks like I'm probably going to lean towards the TSX projectors, is the best place to buy these off classifieds of forums? And what do people mean by 'I want clear lenses if possible'?
Would I need a chrome shroud or anything like that?
Old 06-22-2007, 10:49 AM   #11 (permalink)
The clear lense projector has a sharper cutoff. The freshneled lense has a blurrier cutoff. Most people prefer the sharper cutoff. The clear lense was the first batch of TSX projectors and the freshneled lense are the latest and most recent batch. They changed them (I think) because the blurrier cutoff is 'better' for your eyes.
You can find TSX projectors on forums and on ebay. Sometimes the forum is cheaper and sometimes ebay is cheaper. On both of them, you have to look out for shady individuals. Read the detail and check feedback. HIDPlanet has a lot of stuff in place to prevent fraud though. PMs are not allowed to prevent back dealing, members have to take a picture of what they have along with their user name and the date, and members can't post email until a deal is done.
Edit: Lexus projectors are not easier to put in. A projector is made to fit in the particular car's headlight is designed to go into. Ease of retrofit has to do with the size of the projector and how the projector was actually mounted in the car it came from. The TSX projector has two mounting holes on each side and is designed in a way that makes it easier than most to retrofit in other headlights.
Old 06-22-2007, 11:14 AM   #12 (permalink)
n8dogg455's Avatar
View n8dogg455's Photo Gallery
don't rule out the FX projectors
they will make you work harder for more color, but i have no complaints
being one of the smallest bi-xenon projectors make it easier to fit them
just rememeber to take your time
~07 Magnetic Grey SE I4 ~
FX35's ~ 4300k Philips D2s ~ Matsushita Gen3
Blazers ~ Side Indicators ~ 6 Superflux Per
40% Silver Tint ~ 36 LEDS In My Trunk ..... http://www.putfile.com/n8dogg455/images
Next Projects: IS300 Fogs ~ Superflux Tails / Turns / Reverse
n8dogg455 is offline   Reply With Quote
Old 06-22-2007, 11:24 AM   #13 (permalink)
Also, it is possible to have quad high beams. Just because you have separate high beams doesn't mean that you can't get bixenon projectors. You can wire everything so that your high beam bulbs come on and the high beam on your projectors also comes on at the same time. That is a LOT OF LIGHT! It is high beams so you shouldn't turn them on when another car is in front of you anyway.
Old 06-22-2007, 11:30 AM   #14 (permalink)
HID/Retrofit Expert
Lexus HIDs are no easier to retrofit than any other projectors. Every projector is designed for a specific car, and only that car.
Toyota is not giving an HID option on the Camry because the Camry projectors are halogen projectors. They are not designed to house HIDs. Luckily for many of the members here, the projectors on the Camry take decently well to HIDs with minimal glare (and none at all if you cover the squirrel spotters), but putting HIDs into the stock Gen 6 projectors will yield a worse overall light output than retrofitting true HID projectors.
Why didn't Toyota put HID projectors in the Camry? I don't know. I'm sure they have their reasons.
Old 06-22-2007, 11:33 AM   #15 (permalink)
HID/Retrofit Expert
Well, it depends on the projector you get, and the look that you're going for. Since you're retrofitting the Gen 6, you won't need a shroud, as you can probably use the stock bezel/shroud, but you'll probably need to devise a custom way to mount the projector inside 'cause from what I remember, JSM1284 retrofited TSXs into his Gen 6, and he really had to cut down the mounting bracket a lot and make a custom bracket to mount in order to get it to fit.
FS: E46, Full Projector HID Retrofit! Gen3 Clear Headlight +Corners RedPhoenix Car Parts for Sale 10 08-01-2007 09:00 PM
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
hid kit for sale oklalala Car Parts for Sale 6 12-15-2006 11:21 AM
the big set of HID questions 02whiteLE Camry & Solara Lounge 4 05-28-2006 10:18 AM
HID Projector Retrofit BahamutX Camry & Solara Lounge 13 07-01-2004 11:33 PM
