audio system questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2007, 11:49 AM   #1 (permalink)
Support Authenticity!!!
moky-tron's Avatar
View moky-tron's Photo Gallery
Gen6 audio system questions
for the gen6,
what size speakers do we have in the front and the rear? and the tweeters too?
and how many preouts does the stock headunit have?
thanks
moky-tron is offline   Reply With Quote
Old 06-24-2007, 11:52 AM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
6x9's all around and i believe no preouts
MrSo0h0o is offline   Reply With Quote
Old 06-24-2007, 12:05 PM   #3 (permalink)
moky-tron's Avatar
that makes things quite difficult then...
have any of you guys used a 6.5" with an adapter for the front speakers yet?
Old 06-24-2007, 12:50 PM   #4 (permalink)
steveyhustle's Avatar
View steveyhustle's Photo Gallery
you dont need a adapter lol just got to get a plate made to make em fit in the front but thats wat i got in my car cuz mine are al 6x9s all around but i had aplate made to make a set of 6.5 compenent set to fit in front, i work at a stereo shop so i kno lot bout it[;
Catch me in ya city,
Sittin Pretty,
You know im shinin' dog!
steveyhustle is offline   Reply With Quote
Old 06-24-2007, 12:50 PM   #5 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
I am pretty sure nobody has done that to their Gen6 yet, but I know these adapters exist. I think Crutchfield carried them.
Speaking of preouts...suppose I wanted to add a sub in the trunk. I have the JBL audio. If there are no pre-outs, then I guess the only way to get the audio signal and "auto-on" would be to tap into the rear speaker wires, right?
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 06-24-2007, 12:57 PM   #6 (permalink)
MrSo0h0o's Avatar
yes u would have to use a line out converter and tap into the rear speakers to hook up your sub with amp to your stock system
Old 06-24-2007, 02:55 PM   #7 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
What is a line out converter?
Old 06-24-2007, 03:04 PM   #8 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Those adapters or plates would be easy to make with a scroll saw an a piece of MDF or other wood.
You can get a line-level converter that will take the signal from your rear speakers and attenuate it to the level needed for an amp. Some amps have high-level in so you may not need the line level converter.
2007 Camry 2.4L 5M
Old 06-24-2007, 03:05 PM   #9 (permalink)
A line level converter attenuates the speaker signal (high-level) to line level which is usable by an amplifier.
2007 Camry 2.4L 5M
Old 06-24-2007, 04:35 PM   #10 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
I have. I got adapters in place for the 2 front speakers. I replaced my stock speakers with JBL speakers. I did not buy the JBL system when I bought my LE.
Old 06-24-2007, 04:54 PM   #11 (permalink)
moky-tron's Avatar
so theoretically, i can either make my own mdf adapter for the front which would carry the 6.5", and for me to be able to use a subwoofer, i would need a line level converter which would tap on to the rear speakers, but thereby "killing" my rear speakers too right?
Old 06-24-2007, 04:56 PM   #12 (permalink)
The rear speakers will still work.
2007 Camry 2.4L 5M
Old 06-24-2007, 05:17 PM   #13 (permalink)
wel if your going to put new speakers better put power to them with a amp or u wont get wat ur paying for cuz they wont get the power they need to run there full potential and as for a subwoofer. tapping into ur back speakers wont do nothing u would need a HILOW converter that connects to ur stock headunit and gives u pre outs to run rca's to a amplifier that wil power ur subwoofer hilow converter only run like 20bux.
Sittin Pretty,
Old 06-24-2007, 07:17 PM   #14 (permalink)
View ieee_raider's Photo Gallery
Here's the cadillac line-out converter:
MTX re-Q Bass restoration signal processor. It has both high and sub output. Basically most of your factory radios now have a feature that limits the bass the more you turn up your radio in order to save the speakers and give you less distortion. This also limits your subwoofer signal if you're adding an amplifier. This unit takes care of that and also boosts your rca output to your amplifier. This unit also gives you the delayed remote output to turn your amp on.
2007 Camry XLE V6 - Black / Bisque - Heated Seats, Smart Key, Stability Control
And... My Truck - 2004 F-150 SCab
ieee_raider is offline   Reply With Quote
Old 06-24-2007, 08:23 PM   #15 (permalink)
moky-tron's Avatar
oh i know i need amps for it. i have something lined up already. i just wasnt sure what else i need. ive done lots of audio setups before but none that had needed hi-low converters because i always switched out the headunit. im just thinking along the lines of keeping my headunit stock this time around, to see what my options would be
Do-It-Yourself : Check Engine Light - Diagnosis bonnie* Archived Corolla threads 5 01-01-2007 02:12 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
2003 Corolla - Audio system design / install help Zyphir Audio, Video, and Security - Tech 10 10-10-2005 03:02 PM
A/C system questions Racke Camry & Solara Lounge 15 05-03-2004 03:57 AM
