Subs with stock stereo? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2007, 04:36 PM   #1 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Gen6 Subs with stock stereo?
I have a pair of subs from my previous car that are pretty much just sitting around. And I was thinking, is it possible to connect them to the stock receiver/stereo? I just tested it by connecting the rear speaker cables to the amp and the subs did work, but was distorted (probably from the higher voltage?), but I was thinking that it could be possible if I connected it to the FL and FR wires coming out of the receiver.
And does the standard model have the amp under the passenger seat, or is that just the JBL model?
geoff5093 is offline   Reply With Quote
Old 06-25-2007, 04:39 PM   #2 (permalink)
Posting via Handheld
wireless's Avatar
View wireless's Photo Gallery
Ideally to minimize distortion and allow for the best sound reproduction you should have an amped matched to the subs and get a line level input. Do you have the JBL system?
This is where you insert your signature
wireless is offline   Reply With Quote
Old 06-25-2007, 04:58 PM   #3 (permalink)
geoff5093's Avatar
Forgot to mention that I do have an amp that was paired with the subs in my previous Camry.
And no, I don't have the JBL system.
Old 06-25-2007, 05:29 PM   #4 (permalink)
View DiLan's Photo Gallery
You need a line level out converter, $15+ and then u need to connect the cables to your rear speakers. That will give you 2 RCA outs which you can then connect to your amplifier
1990 Camry LE V6 25th Anniversary Edition
DONE:Sony Xplod 800W Amp(XM-1252GTR) w/ Dual Kicker Subs, Alpine CDE-102 Deck, New Eliminator Battery, Keyless Entry
TO DO:Intake adapter, fix wheel well rust
*SOLD*2007 Camry I4 SE Alpine White
http://www.cardomain.com/ride/2571595
DiLan is offline   Reply With Quote
Old 06-25-2007, 05:42 PM   #5 (permalink)
yeuemhoai's Avatar
View yeuemhoai's Photo Gallery
Some amps already have speaker level inputs such as the Kenwood KAC-8101D I have, you only need to tap into both rear speakers.
'07CamryLEV6|Whyt|V4|EF|Mudguards|All-weatherMats|LipSpoiler|Tinted|3MProtector|LEDInterior|SERims|Xtreme5000K| LEDTaillights...
'01LexusRX300|PearlWhyt...
'96CamryLEV6CollectorEd.|PearlWhyt...
yeuemhoai is offline   Reply With Quote
Old 06-25-2007, 05:46 PM   #6 (permalink)
geoff5093's Avatar
The one I have only has one set of RCA inputs. I actually have the entire dash apart now and i'm going to try tapping into the front left (FL) and front right (FR), and see if that sounds any better.
Old 06-26-2007, 01:21 AM   #7 (permalink)
steveyhustle's Avatar
View steveyhustle's Photo Gallery
actually to hookup a amp kit just buy a hilow converter whihc gives u rca outputs run cables down to back of ur car to ur amp and connect subs there easy shizz no need to tap into rear speakers. unless connectin 4channel amp
Catch me in ya city,
Sittin Pretty,
You know im shinin' dog!
steveyhustle is offline   Reply With Quote
Old 06-26-2007, 07:54 AM   #8 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
i tried to hoop up my old bazooka bass tube to the rear spks like i had it set up in my old 300zx. sometimes it worked sometimes it didnt. weird. i just took it off and put it in the attic.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 06-26-2007, 08:13 AM   #9 (permalink)
geoff5093's Avatar
I decided to just tap into the left and rear outputs from the HU, now i'm trying to find a way to route the cable throught he firewall.
Old 06-26-2007, 09:42 AM   #10 (permalink)
Francois L'Ollonais
lollonais's Avatar
View lollonais's Photo Gallery
Dude, go to RadioShack buy the speaker wire to RCA connector adapter. Tap your rear speaker wires and connect the RCA to your amp. Thats it, why go through all that hassle.
2007 Black Camry CE
20% Black tints, Prestige Alarm with Solenoid for Trunk
2009 Pearl White Highlander Hybrid Limited
Navigation Package OEM everything except overhead DVD
lollonais is offline   Reply With Quote
Old 06-26-2007, 09:48 AM   #11 (permalink)
yeuemhoai's Avatar
That's what Dilan's recommend, buy level-out converter, open up your trunk, tap them into both L/R speakers and the RCA to the amp. This way you don't have to run wire from front to back.
Old 06-26-2007, 09:51 AM   #12 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
i think starting from 2008 all headunits should have RCA outs for subs, unless the car came with subs from the factory using different connectors.
but i'd do what others have suggest instead of running cables front to back...thats a pain.
nodrogkam is offline   Reply With Quote
Old 06-26-2007, 11:07 AM   #13 (permalink)
geoff5093's Avatar
I know I could have done that with a converter, but this way when I want to switch out my HU, i'll have the wiring for the amp already in place.
Old 07-03-2007, 09:56 PM   #14 (permalink)
redwings7907's Avatar
View redwings7907's Photo Gallery
rear speakers
can anybody tell me which one of the rear speaker wires is + and which one is -? one is yellow and one is red.
btw...i have the jbl system with nav.
redwings7907 is offline   Reply With Quote
Old 07-03-2007, 10:03 PM   #15 (permalink)
nodrogkam's Avatar
well im just gunna guess that the red is positive and the yellow is negative.
typically the connector for the positive is larger than the negative. jus make sure the stereo and shit are off when ur connecting the stuff...dun wanna blow something on accident.
*DIY* Stock Stereo LED color change - (Lots of PICS) - 56k no way SnakeyeS Camry & Solara Lounge 56 12-09-2010 02:51 AM
What's good, what's not so good(Car Audio Products) cam2Xrunner Audio, Video, and Security - Tech 166 02-03-2010 12:57 PM
A good asking price for stock stereo? wiggum21 2nd Generation (2005+) 2 06-06-2006 02:03 PM
Factory part number for '06 stock stereo? Celica4life Scion Forum 5 08-11-2005 01:36 AM
