Questions About Gas for Drag Racing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2007, 01:04 PM   #1 (permalink)
View DBIGMAC1's Photo Gallery
USA Questions About Gas for Drag Racing
So about a dozen friends and I are going to the drag strip next week to race each other. My '07 camry accelerates a lot better than my '95 did and I think I have a good chance against my friends (the track also provides handicaping). I normally run an 87 octane and regular oil (it's a lease otherwise I would use syn.)
Will going to a 93 at the pump or an even higher octane at the track add any noticeable advantage?
Is there any advantage for a K&N filter (just standard filter replacement) or a syn oil like Q's horse power boost or Mob1 Syn?
Thanks! I'll come back with some 1/4 times too.
'07 Camry LE 2.4L Silver
'95 Camry LE 2.2L Gold
DBIGMAC1 is offline   Reply With Quote
Old 07-02-2007, 01:12 PM   #2 (permalink)
Posting via Handheld
wireless's Avatar
View wireless's Photo Gallery
Personally, I would run a mix of 3:1 CAM2 fuel. You could probably run a higher ratio...but with the assumed lackof precision of the amatuer mix...go for 3:1 to err on teh side of caution.
I have a K&N in my SE V6 and really don't notice a difference in acceleration. I am sure if it was coupled with exhaust and some other things to truly complete a stage 1 upgrade of additonal airflow in, airflow out, and better fuel mixture I would be telling a different story.
My wishlist:
TRD Exhaust (Borla mufflers)
Intake (When either Fujita or Sceptre get their $h!t together)
This is where you insert your signature
wireless is offline   Reply With Quote
Old 07-02-2007, 01:34 PM   #3 (permalink)
Gotta Love Twins!
TRD-98TT's Avatar
View TRD-98TT's Photo Gallery
Actually it is a complete waste of time and money to put in any higher octane fuel than 93 into a car still utilizing the stock ecu. The higher the octane the fuel, the slower and cooler that it burns thus causing the car to run more rich than tuned from the factory. If the car runs too rich, you will actually loose horsepower so just use 93 octane and have a good time. If you want to get a better time, focus on your 60' time. Also, if you are using your street tires, make sure that you miss the burnout box and do not do a burnout. Street tires do not heat up like a drag radial or slick when a burnout is performed (you just burn off tread). Do you have a V6 or I4 and is it automatic or manual?
-Ryan
TRD-98TT is offline   Reply With Quote
Old 07-02-2007, 02:28 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Higher octane will not help you at all. As stated above, it will probably hurt performance.
A K&N or TRD filter will help a little bit. You won't feel it and you'll be lucky to get a tenth in the quarter.
Synthetic oil will also help you a little bit. Again, you won't feel it and will be lucky to get a tenth.
A little web searching will yield you the same answers.
2006 Camry LE Special Edition
Old 07-02-2007, 02:36 PM   #5 (permalink)
wireless's Avatar
-Ryan
Good call...I haven't been on a drag trip in over 8 years in anything but a force fed car with aftermarket ECU...not a N/A.
Old 07-02-2007, 03:01 PM   #6 (permalink)
Gotta Love Twins!
TRD-98TT's Avatar
Not a problem at all and the key is ECU. Now if you have a stock car (N/A or FI) but upgraded the ECU to a tunable/programable one, then you could run a higher ocatne fuel as long as you tune the car for the higher octane. Yes, you will not see significant gains on a stock motor compared to a built one but it will perform better than factory specifications.
-Ryan
Old 07-02-2007, 03:34 PM   #7 (permalink)
I have the I4 auto with everything stock.
My local Toyota dealership offers free Nitrogen Tire Service, I know that's what NASCAR requires of all tires used, does anyone know if that would help too?
Old 07-02-2007, 03:44 PM   #8 (permalink)
Gotta Love Twins!
TRD-98TT's Avatar
To be blunt, you have a stock automatic 4 cylinder . You are just wasting your money on these little things here and there that will not do a single thing for you at the track. Just go there and have fun and do not be disapointed with the times that you end up running.
-Ryan
Old 07-02-2007, 07:04 PM   #9 (permalink)
TRD VVTi's Avatar
Gen5
Do it. It won't help your performance but nitrogen is superior to plain air.
You can't beat free, even if the benefit is minimal.
gas questions njcamry 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-16-2006 08:54 PM
Motorists urged to drive less as gas supplies drop Lord_Anarchy General Discussion 4 09-01-2005 09:29 AM
new 4runner questions andyjl 4Runner Lounge 14 04-12-2005 03:51 PM
GAS question? how long does... BILLSHEA99 General Discussion 9 05-04-2004 11:51 AM
We have the power to reduce gas prices! EuroCamz General Discussion 32 04-10-2004 05:53 PM
