Cruise won't work... shift display out... - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2007, 11:08 AM   #16 (permalink)
View es336td's Photo Gallery
USA Getting progressively weird...
Ok... tally of failures...
1. Cruise control - light comes on but cruise will not engage.
2. Shift indicator - no lights, but no problems with shifter going in gear
3. Auto door lock at speed - just stopped. Locks work, but don't do the thing when you get up to a certain speed.
4. Rear defroster... the light comes on, but the coils don't do anything.
5. Back up lights... do not come on when car is put into reverse.
Are these all on the same circuit? Just curious if it's something stupid I've overlooked.
I've checked all the fuses and they appear fine. I have not yet checked for continuity. I really would hate to spend the diagnostic fee if it's something simple.
Thanx.
es336td is offline   Reply With Quote
Old 09-25-2007, 12:50 PM   #17 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $455050
View Luna2's Photo Gallery
Gen6
Thanx.
Recheck the 10A Gage 2 fuse, it is the common source with Item 1, 2 (may be the others). Also Ign 1 relay is ahead of the fuse. (Check fuse for 12v on the top.) Good luck!!!!
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 09-25-2007, 12:56 PM   #18 (permalink)
USA
What I don't understand is why things like the cruise and rear defroster lights come on but the function they provide doesn't work... weird...
I'm quite the idiot, so are the fuses actually labeled Gage 2 or Ign 1? And these are in the engine compartment or to the left of the steering below the steering wheel? Thanx.
L
Old 09-25-2007, 01:55 PM   #19 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
1.-cruise control is controlled by the ecu. if the light comes on i would say the ecu is bad or one of the relays controlled by the ecu is bad. bad tps, bad throtle control motor. pg 190 of the online manual.
2.-if none of your lights work I would say your combination meter is bad. or a lose connector. pg 218/266/212 of the online manual.
3.-locks controlled by ecu. pg 154
4.-bad def relay. pg 246 of the online manual. not related to ecu at all.
5.-back up light very simple switch, probably located around the shifter pg 142. not related to ecu at all.
sounds to me like your ECU is having problems. get ready for big bucks.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 09-25-2007, 01:58 PM   #20 (permalink)
USA
Sorry to be dense... but do you have a link to the online manual? Thanx.
Old 09-25-2007, 03:31 PM   #21 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
http://camrymanuals.com/
gdanaher is offline   Reply With Quote
Old 09-25-2007, 03:37 PM   #22 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gen6
Activate command for the relay and light is from another source. The real power is through the contacts on the relay and is fused seperately. The correct fuse to check is "GAGE 2", located inside the dash.
The link to the manuals is at: http://www.camrymanuals.com/.
NOTE: There is a relay in front of that fuse. On top of each fuse is a place to test for power on each pin. Find a good ground for the tester and probe the "test pads" of the fuse, while installed, IGN should be in the run position in this case. Good = power on both spots.
Good luck
MFG 02/25/2010
Stock, Shucks!
Old 09-25-2007, 03:39 PM   #23 (permalink)
carlo$'s Avatar
perfect, look at the complete electrical manual.
http://camrymanuals.com/index.php?=&...&~=00X187A#199
2005 LE 4 cyl
Old 09-25-2007, 08:16 PM   #24 (permalink)
The Connoisseur
CharmCityES's Avatar
wow this is quite unusual in a car this new....i have an 03 SE I4 and i only have 50k and have had no issues at all
make sure you check all your relays and fuses first, as they are usually the root of your issues...
the fact that all this is happening on a few unrelated circiuts leads me to assume its an ECU issue.....if it was just one thing like the back up lights or cruise i'd say you have a short to ground or something simple....but this points to a larger issue
i can look the issue up on TIS techstream at school on thursday and see if theres any reposted cases of similar occurances and solutions
The "Executive Sedan"
Old 09-26-2007, 06:25 AM   #25 (permalink)
USA
This could explain the age... I drive almost 100 miles round trip every day to work. The car is a 2005 SE... I currently have over 83K on it now.
Old 09-26-2007, 06:26 AM   #26 (permalink)
USA
Old 09-26-2007, 07:25 AM   #27 (permalink)
carlo$'s Avatar
its a camry (daily beater), its suppossed to be go to 250k+ miles. provided you give it good maintenance.
unless camrys are not what they use to be.
that is why i bought a camry; fuel economy & long lasting.
i hope i am not dissapointed in the near future.
2005 LE 4 cyl
Old 09-28-2007, 12:01 PM   #28 (permalink)
USA Mystery solved!
Well, last night I went out with a pair of needle nose pliers and my VOM. I pulled each fuse and checked it for continuity. When I got to Gauge 2, it was blown. I swapped it with the Heated Mirror 10A (I don't have heated mirrors) and everything came back! Cruise, shifter lights, back up lights, defroster... Damn glad I didn't take it to the dealer and pay the diagnostics fee to find it was a blown fuse! Thanx to all the responders!
Old 09-28-2007, 02:05 PM   #29 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gen6
Now to the real question, ROOT CAUSE.
What was hit during the cleaning session that caused the fuse to open???
There might be a problem developing, a design flaw, an unusual event, or something was done that shouldn't have been.
Just some food for thaught.
Glad it's working!!!!!!!!
MFG 02/25/2010
Stock, Shucks!
Auto Transmission, 1-2 shift after sitting ALWilson T-100 21 02-04-2009 06:13 AM
Brake lights won't work when headlights are on... Psykosoma Yaris, Vitz and Echo Forum 11 01-19-2008 03:38 PM
Prison VS. Work Cyorke Off Topic 10 01-19-2006 05:50 PM
Problem with cruise control - 4runner 1993 400km 4Runner Lounge 0 01-03-2006 07:25 PM
Gen5 transmission 1-2 shift JasonH 5th & 6th Generation (2002-2006 & 2007-2011) 13 05-09-2004 04:53 PM
