Originally Posted by tymekeeper
HI All,
Anyone have problems with the cruise control downshifting at the slightest incline? At 60mph I can see a slight increase in the tach from about 2k to 2200 rpm on a real slight incline butEven on a bit more of an incline it will downshift harshly ang over 3K rpm. I real pain in the ass.
Will the aplication of the TSB EG056-06 solve this problem? Will I get better or worse gas milage with this TSB applied?
That's how the cruise control is supposed to work.
1. Applies some throttle 2. unlocks torque converter 3. Downshifts to 4th gear. 4. Downshifts to 3rd gear if the slope is steep enough and then upshifts as the slope lessens.
The I4 below 2,500 RPM has not a lot of torque or HP and 5th gear is OD.
Don't like it, disengage the Cruise and watch it downshift as you try to maintain (not lose) speed on an incline.
