2002 Camry - Rear Drum Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2007, 06:51 AM   #1 (permalink)
View stevei54's Photo Gallery
Can someone help me with the trick to get the drums off on a 2002 Camry. I tried loosing up the brake thru the hole in the drum - but it appears that you need either some screws - wondered what size they would be to push the drum off?
stevei54 is offline   Reply With Quote
Old 07-09-2007, 09:01 AM   #2 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
^Bolts are pretty cheap. Measure the diameter of the hole as best as you can, and then go to the hardware store and grab a few metric bolts with diameters that are close to what you measured, and try each one.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 07-09-2007, 08:17 PM   #3 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
Time to get the BFH out
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Whiteline MA70 Front/Rear Adjustable Swaybar GroupBuy!! raptorracing Supporting Vendor Sales 30 04-27-2007 03:27 AM
'92 Camry Rear Thumping Noise - PLEASE HELP ltat 3rd & 4th Generation (1992–1996 & 1997–2001) 5 12-26-2006 12:24 AM
2002 Camry XLE Radio Removal mistermonday Camry & Solara Lounge 1 09-07-2006 06:01 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
2005 Camry Rear Suspension Noise deban 5th & 6th Generation (2002-2006 & 2007-2011) 5 11-15-2004 03:55 AM
