I had an alignment done and there are a few things I don't understand. What is "SAI" and "Included Angle"?
The alignment printout shows a specified range of 10.7 - 12.2 for SAI. My front left shows 8.7 and my front right shows 4.4. Both well out of the specified range.
The alignment printout shows a specified range of 9.2 - 12.2 for Included Angle. My front left show 7.4 and my front right shows 3.8. Again both are well out of the specified range.
The alignment shop says those numbers don't mean anything and they are not adjustable. He says the numbers are there just to aid the tech in properly setting the camber, caster and toe.
Is the alignment shop giving me the straight scoop or is there something here I should be concerned about? FYI, camber, caster and toe are in spec (barely)
SAI- Steering Axis Inclination.
Included angle- The combination of Camber and SAI
Steering axis inclination and included angle are often used as diagnostic tools. Steering axis inclination, or SAI, is defined as the angle formed by a line drawn through the upper and lower pivot points and a vertical line from the center base of the tire, when viewed from the front. SAI is measured in degrees. Camber is defined as the inward or outward tilt of the wheel at the top, as viewed from the front. Camber is usually specified positive on front wheels. Included angle is the combination of SAI and camber.
They are not feeding you crap. Your measurements are fine.
__________________ Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals My friends call me The Cane. Even before I messed up my leg. ~Dr. Gregory house
SAI is just a little high, You add the numbers together, but nothing to worry about. The included angle is within the correwct range.
2005 Lexus ES330
Your fine.
You can Google alignment specifications and come up with the same answers.
Camber, caster, and toe are the only things you really need to be concerned about.
It would be easier if you would post your printout to see if they did a good job or not. Just having it "in spec" doesn't tell the whole story.
Correct, Any tech can push on the vehicle and freeze the screen to show it in spec.....
2005 Lexus ES330
I don't have a way to scan the printout. Here is the "Specified Range".
Camber -1.5 to 0.0
Caster 1.9 to 3.4
Toe -.10 to .10
Cross Camber -.8 to .8
Cross Caster -.8 to .8
Total Toe -.20 to .20
