Originally Posted by JAG66
Thanks for the info, I will pick one up. Also, how tight should the filter can be?
The specs come with the Toyota cartridge on the box
Cap ==> 4 ft lb.
drain plug on bottom ==> 2 ft lb.
The small o-ring takes some "finessing" to pop it in.
It really is the right size
If the drain plug bolt is too tight to get out with the 3/8 socket wrench, their are two flats cast into the threaded end that allow you to put the case in a vise to get better leverage on the bolt.
It is really easy to change the oil filter cartridge.
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
