Removing hoodliner - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2007, 04:09 PM   #1 (permalink)
fredberg's Avatar
View fredberg's Photo Gallery
Gen5 Removing hoodliner
hey y'all, jus wanted 2 know the best way 2 remove the hoodliner. i see the tabs/clips holding it in, but i dont want to break them while popping them off. btw, im doing this to dampen the hood. thnx 4 any input!
fredberg is offline   Reply With Quote
Old 07-15-2007, 04:30 PM   #2 (permalink)
2006 Camry Base
View whiteboy's Photo Gallery
i removed a couple with pliers but I think you can try a trim remover tool, I got one of those later but I took them off to check out the nozzles heh but umm ya they dont break that easy but i'd say go take a look how they look like and think of something :-) but trim remover tool 90% sure if I remember the clips right
whiteboy is offline   Reply With Quote
Old 07-15-2007, 04:37 PM   #3 (permalink)
Mistabullet's Avatar
View Mistabullet's Photo Gallery
Where do you get the trim remover tool? I just used a screwdriver wrapped in black tape.
Mistabullet is offline   Reply With Quote
Old 07-15-2007, 04:54 PM   #4 (permalink)
2006 Camry Base
I got mine at autozone it wasnt much either, not the least expensive item i got but it's not much it's just a handle with a split end basically
Old 07-15-2007, 05:35 PM   #5 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
iTrader Score: 7 reviews
so what exactly does pulling the hoodliner off do?
2002 Camry SE V6 "Snow White"
Old 07-15-2007, 05:55 PM   #6 (permalink)
2006 Camry Base
add heat all over the place :-D
Old 07-16-2007, 12:43 PM   #7 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
Gen5
probably make the car nosier too.....
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 07-16-2007, 01:02 PM   #8 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
View white3ch0c0late's Photo Gallery
Removing the hoodliner is not a very good idea. The hoodliner absorbs a great amount of the heat created by the engine. Without the hoodliner there, your paint is going to bubble up on your hood.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 07-16-2007, 02:12 PM   #9 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
No it's not. Where do you come up with this crap?
2006 Camry LE Special Edition
Old 07-16-2007, 03:21 PM   #10 (permalink)
View onsknht's Photo Gallery
Removing the hood liner will not damage your paint... The sole purpose of the hood liner is to extinguish sound.
There are actually advantages to removing the hood-liner.
1. engine runs cooler, the heat isn't retained as much while stopped idling.
2. snow doesn't accumulate on the hood while the engine is on
3. saves weight
4. easier to clean the underside of the hood
5. looks brighter under the hood cause the paint shines, the dull cloth doesn't
BUT, I think he was asking cause he wants to add material to deaden sound?
2GR-FE
onsknht is offline   Reply With Quote
Old 07-16-2007, 03:59 PM   #11 (permalink)
HID/Retrofit Expert
Cause I've seen it, douche-y.
EDIT:
Hmm.. nevermind. What I saw was a hoodliner after it caught fire, which caused the paint to bubble.
Old 07-16-2007, 04:40 PM   #12 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
I don't think douchey would be a very good nickname for a child. Talk about getting teased all the time. Especially if mom asks little douchey to "Clean up.". Anyways, bad joke and you guys may continue.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 06:53 PM
Removing rear sway bar because of rattle noise. green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 13 02-16-2008 05:53 PM
Removing Lenses Illegal in CA? OneMnk 2nd Generation (2005+) 9 02-02-2006 03:46 PM
removing the pinstripe bowlofturtle Camry & Solara Lounge 17 06-19-2004 02:38 PM
