2002 Camry I4 - CEL P0500 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2007, 04:10 AM   #1 (permalink)
Unofficial TRD Whore
View iAMconfused's Photo Gallery
recently, my I4 XLE camry with abs came up with a cel P0500 - Vehicle Speed Sensor A Malfunction. Could someone tell me where the vehicle speed sensor is located? i doubt this thing's hard to service, but so far i have no luck finding it. if anyone has its location please let me know asap, thanks.
Eh?
iAMconfused is offline   Reply With Quote
Old 07-16-2007, 10:07 AM   #2 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
i had the same problem.. the car shifted like shit in my 05 till i got it changed. Heres what it says on the recpt... "Tech replaced speed sensor Found failed for code PO500"...Parts....Decription-Sensor, Transmiss. It also has a part # 89413-08020 (keep in mind this is for an 05 with the 5 speed auto) not the 03
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 07-16-2007, 03:08 PM   #3 (permalink)
my local autozone carries the part, but if i want to replace it myself i need to know where it is...moreover, it says vehicle speed sensor a...so i'm assuming there's more than one, therefore i need to know exactly where "a" is.
Eh?
Old 07-16-2007, 03:35 PM   #4 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen5
my guess would be somewhere near the driveshaft before it goes into the diff. Just look for wires going in/arround the trans.
Old 07-16-2007, 06:51 PM   #5 (permalink)
View toyomoho's Photo Gallery
Does the speedometer work OK? If so, the sensor is OK. Look on top of the differential housing. It is held in by one bolt, has two wires attached via a plug. Also check the wiring.
Old 07-17-2007, 08:09 PM   #6 (permalink)
the speedo's reading fine, but when the code pops up the auto tranny would just bog down like it's high on drugs. so according to what you're saying, it's probably the wiring. recently the code hasn't came back though...when it comes up again i'll crawl down there and check it out. thanks.
Eh?
Old 07-24-2007, 11:01 PM   #7 (permalink)
ok so i found the vehicle speed sensor...but when i look up the catalog, there's also a "front/rear speed sensor (right/left)." how do i know if the description on "vehicle speed sensor a malfunction" is the one sitting above the auto transmission?
i should also mention...so far i haven't seen any abs light go up, only erratic shifting on the auto transmission, and sometimes it won't go over 40mph (which is probably because of the poor shifting didn't go up gears). if i try to clear the code, the p0500 cel would random come back on whenever it feels like it.
Eh?
Old 07-26-2007, 09:26 PM   #8 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen5
I know when it happend to me the car got stuck in 3rd and i hit the rev limitor then droped into 4th and lurched forword very hard. Also On a cold start it would go over 3000 rpm's then drop to 1000 and back up too 2000
Old 12-30-2007, 12:04 PM   #9 (permalink)
View slc97sr5's Photo Gallery
I got my Wife's LE to do it today...only code the 2005 has ever thrown since new. I was messing around in the snow with the e-brake and hitting the gas. The ABS does not like that and after about 3 minutes it tossed a CEL P0500 per a ScanGauge II. I reset the light and it has not returned...we'll see.
I attribute this entirely to my dicking off.
slc97sr5 is offline   Reply With Quote
Old 03-21-2009, 05:15 PM   #10 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
I encounter a fail smog today due the P0500 code, When i went to get my car smog today, there was no check engine or nothing, what can cause the speed sensor to malfunction during a smog test
LoudCamry is offline   Reply With Quote
Old 03-31-2009, 01:38 PM   #11 (permalink)
SkinnyConHeo's Avatar
View SkinnyConHeo's Photo Gallery
2007 Camry LE just gave this code, do I need to take in for a part replacement?
Problems I've fixed with the help of this forum:
The brakes squeak annoyingly.
Problems I still need help with:
Driver lock button locks all doors BUT driver's door.
Driver electric seat buttons and gas door switch don't work.
SkinnyConHeo is offline   Reply With Quote
Old 06-02-2010, 06:00 PM   #12 (permalink)
View camryen08's Photo Gallery
Hi, did you replacement anything for this issue?
Did the replacement works ( at least no same code pop up? ) and how much it cost you?
Thanks.
camryen08 is offline   Reply With Quote
Old 06-02-2010, 08:41 PM   #13 (permalink)
View MstrToyoTech's Photo Gallery
from tis..
check wires to ecm.. code is thrown on the v6's as well.. is your speedo works and does not skip around and looks normal the sensor is fine
MstrToyoTech is offline   Reply With Quote
Old 10-24-2011, 09:32 AM   #14 (permalink)
toyo luva luva
leosv's Avatar
View leosv's Photo Gallery
Just as info in case anybody else experiences it...
One of my headlamps blew out and two days later my car was acting funny with lights flickering. My dome light would turn off when I would open the door and the chime would only work once, just like as if the battery was dead. The car started fine though. The next morning on the way to Auto zone to get a headlight, the CEL came on with the P0500 code (checked at autizone), and at the same time my ABS light came on and my radio turned itself off. 5 minutes later everything was working fine but the CEL was still on. I got home, replaced the headlamp, and the CEL turned off.
Gotta love electronics. I'm just gonna write this one off and pretend it never happened. lol
leosv is offline   Reply With Quote
Techna-fit Brake/Clutch Line Group Buy: All Makes/Models raptorracing Supporting Vendor Sales 230 08-27-2007 12:22 AM
My experience w/ a 07 Camry SE I4 auto Linck 5th & 6th Generation (2002-2006 & 2007-2011) 49 08-14-2007 08:05 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
2002 camry V6 vs. 96 2dr camry V6 wheels17 5th & 6th Generation (2002-2006 & 2007-2011) 2 10-23-2004 10:59 PM
