questions for anyone with Toyota Remote Engine Start for 2007 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2007, 11:33 AM   #1 (permalink)
View germandebbie's Photo Gallery
My Camry has the Toyota factory security system. I also plan on adding the Toyota
Remote Engine Start system. Got a few question.... Thanks for helping!
Question 1: how much does it cost to have it installed by a Toyota delership?
Question 2: once the engine is started, do I simply use the key or remote to get into the car, insert the key and drive off, or do I have to turn it off and restart again?
Question 3: if I remote start the engine, how long before the engine will shut off if I don't enter the car?
Question 4: is there a seperate remote for the remote engine start?
germandebbie is offline   Reply With Quote
Old 07-17-2007, 11:43 AM   #2 (permalink)
View 69Stang's Photo Gallery
Dealer in Ohio charged me 200.00 $ labor only, stater was 345.00, hood switch was 60.00.
Yes, remote or key to open, as soon as you open the door the starter will deactivate and you will need to restart the car with the key.
10 minutes.
No it's integrated in the key fob.
69Stang is offline   Reply With Quote
Old 07-17-2007, 11:47 AM   #3 (permalink)
Gameroom cash: $232150
View Joe B's Photo Gallery
and if Toyota does the install,you will have to start it again.
The car shuts down when unlocking and I think the car will run 15 minutes and shut down.
'11 Camry Hybrid Classic Silver/Ash
Moonroof | NAV | Leather | JBL Audio | XM | Blue Tooth | OEM Remote Start | Michelin Primacy MXV4
'11 Honda CR-V EX-L w/NAV 4WD Glacier Blue/Gray
Leather | Remote Start | Fogs | Premium Sound | XM | Wood Dash | Michelin Primacy MXV4
Joe B is offline   Reply With Quote
Old 07-17-2007, 11:54 AM   #4 (permalink)
The car shuts down when unlocking and I think the car will run 15 minutes before and shut down.
Runs for 10 minutes and you can re start it for another 10 minutes, 20 minute max.
remote is only good for 80 ft and the start procedure is a pain in the butt but atleast I have warranty. I hate cold Canadian winters.
Old 07-17-2007, 11:59 AM   #5 (permalink)
Thanks.
Do you have push button start?
Toyota must have just started the cutoff when inlocking recently.
We had a '05 Corolla with Toyota dealer installed remore start and you could unlock,get in,insert the key and go.
Stepping on the brakew would cause the engine to shut down.
A b\much better set up.
Old 07-17-2007, 12:12 PM   #6 (permalink)
no push button, I have the SE V6. There's a couple of models it won't work with, the push button and the CE model........ I think.
Old 07-17-2007, 12:21 PM   #7 (permalink)
Thanks! 10 minutes is plenty long for my needs. However, I'm still confused about
why the car will shut off if you unlock the doors.
I rented a '06 or '07 Chevy Impala from Avis(or was it National?) at LAX airport last year.
I had it for about two weeks and loved its factory remote start system. It has a button
on the remote dedicated to engine start. Once started, the engine will run, but the doors
remain locked. When I unlock the doors with the remote, the engine will continue to run,
but it is not possible to drive off. The steering wheel and the gearshift remain locked.
(for safety, I presume) Once the key is inserted and turned to "on" position, the steering
wheel and gearshift are unlocked, so car can then be driven off....
Does the Toyota system work like that?
Thanks!
Old 07-17-2007, 01:42 PM   #8 (permalink)
Posting via Handheld
wireless's Avatar
View wireless's Photo Gallery
The Toyota factory system (I have in my SE V6) takes a two press/hold of thelock button on the keyfob to start the ignition. Unlocking the car with the key or the fob will cut the motor as will putting the key in the ignition (if you were in the car while it is running).
It a safety (nanny) and security feature. I use it less than I thought I would because of this...but I am glad I got it for resale value (it will be a check box I can fill in when making a reslae valuation/trade in analysis).
As for the 80 ft range comment...why in god's name would you want to start it from further away? Give me a practical application? Oh, and BTW...you can increase the range using the chin trick (uses your body as an antenna).
This is where you insert your signature
wireless is offline   Reply With Quote
Old 07-17-2007, 01:48 PM   #9 (permalink)
Turbo MP3 to 07SE!
JoeS_07SE's Avatar
View JoeS_07SE's Photo Gallery
Why would it kill the engine when you get in? That is absolutely pointless! So you basically have to start it twice, thus causing useless wear and tear on your starter. What a waste!!!
2007 Titanium Camry SE V6, Leather, Moonroof, Rear Lip Spoiler, NAV, Camera, TRD Exhaust, TRD Springs, Camry strut bar, Toyota pedals, Toyota polished Door Sills, 20% 3M Tint, 20" Rozzi's +45 offset, w/ 235/35/20 Nitto 555, E and G Classic Mesh Grille, K&N Typhoon Intake.
JoeS_07SE is offline   Reply With Quote
Old 07-17-2007, 02:00 PM   #10 (permalink)
As for the 80 ft range comment...why in god's name would you want to start it from further away? Give me a practical application? Oh, and BTW...you can increase the range using the chin trick (uses your body as an antenna).[/quote]
How about if you live on 20th floor apartment
chin trick.....please elaborate, never heard of that.
Old 07-17-2007, 02:02 PM   #11 (permalink)
I have the push button start with Toyota installed remote start.
Old 07-17-2007, 02:24 PM   #12 (permalink)
View s0uthstar85's Photo Gallery
Here: Chin Trick
Black 2007 Camry I4 SE - Tabula Rasa
-3M ColorStable Tint: 35% Front, 20% Back
s0uthstar85 is offline   Reply With Quote
Old 07-17-2007, 02:27 PM   #13 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Is the 80 ft range measured outdoors in an open area? If the car is parked outside in the driveway or street and you are inside a building, even if it's a single family dwelling, the house will attenuate the signal and the effective range will be much shorter.
I have a Python security system with remote start capability but I chose not to hook up the remote start for safety reasons. The effective range of my remote is over 500 ft outdoors and about 100-200ft from indoors (with the car sitting outside) depending on how the building is constructed. Another benefit to the Python system is that it gives me confirmation that the car did the command I issued. The downside is that the remote uses a AAA alkaline cell that lasts about 2 months at which point it only puts out 1.0 V.
2007 Camry 2.4L 5M
Old 07-17-2007, 02:38 PM   #14 (permalink)
Originally Posted by s0uthstar85
Wow...thanks for that link...
Is there anything left in the world that people wouldn't find a mod for?
What's next? A flea collar mod that will extend its flea-repelling range to cover two dogs?
(just kidding!)
Old 07-17-2007, 02:42 PM   #15 (permalink)
yeuemhoai's Avatar
View yeuemhoai's Photo Gallery
My car starter only works less than 10 ft at my workplace (copper mesh grounding) and I only use it in the winter moring to warm up the car for my children (wear and tear is less important).
BTW, I paid invoice price of $365 installed at delivery.
'07CamryLEV6|Whyt|V4|EF|Mudguards|All-weatherMats|LipSpoiler|Tinted|3MProtector|LEDInterior|SERims|Xtreme5000K| LEDTaillights...
'01LexusRX300|PearlWhyt...
'96CamryLEV6CollectorEd.|PearlWhyt...
yeuemhoai is offline   Reply With Quote
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Post Whore of the day YESCA Off Topic 2 04-05-2005 12:18 PM
Silver Anniversary Gen3 Camry I4 K-Oss 3rd & 4th Generation (1992–1996 & 1997–2001) 9 07-14-2002 01:46 PM
TCI ANNOUNCES PRICES OF ALL-NEW 2002 CAMRY - F bondobondo 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-14-2001 12:48 PM
