I had this problem too on my 4 door V6 - but i noticed BOTH rear windows would not work. I went to take the door apart til i saw a sticker on the rear door, there is an additional child-proof lever or button thing that you need to turn on, located on the rear doors, its a little lever or button - i drove some people in my car and somebody threw the switch, so putting it back how it is supposed to be (unless you own some dumb kids that like to jump out the window of your car) fixed it.
If only the one window doesnt work though, and the other 3 are fine, here's some things to check.
Remove the switch or wire in any other kind of switch temporarily to close the contacts and see if the window now works, if it does, you know what to do.
if this doesnt do it remove the panel and jiggle the wires on the window motor, bang on it a little, see if you can make it work or get some movement out of it. If you can hear the window motor trying to work, maybe the glass is jammed in its track and the motor can't move it.
Peel back the rubber boot covering the wires at the door connector and look for fraying etc.
Use a vom or trouble light and check for power to the motor. Also check for power at the switch.
If messing with the switch does nothing, and the motor is getting power, you probably need to change the window motor.
